Epson LQ 2090 Mono Dot-Matrix Printer
Quicklinx: 65P1WS00 Mfr#: C11C559012A1
The Epson LQ-590 and Epson LQ-2090 bring exceptional performance to the 24pin segment. In addition to high speed printing up to 529 characters per second, they are extremely compact, robust and reliable. This is perfect for the relentless everyday demands of busy environments like doctors´ surgeries, banks, travel agencies and freight forwarders. Versatile paper management also comes as standard, for fast, flexible printing of orders and invoices, labels, system event logs, cheques and barcodes.
Epson LQ 2090 - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
9.5 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Print Speed
Up to 529 char/sec - fast draft , Up to 440 char/sec - fast draft , Up to 396 char/sec - draft , Up to 330 char/sec - draft , Up to 132 char/sec - letter , Up to 110 char/sec - letter
Parallel, USB
RAM Installed (Max)
128 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Microsoft Certification
Works with Windows Vista
1-year warranty
61.3 cm x 37.5 cm x 17.2 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 529 char/sec - fast draft - 12 cpi , Up to 440 char/sec - fast draft - 10 cpi , Up to 396 char/sec - draft - 12 cpi , Up to 330 char/sec - draft - 10 cpi , Up to 132 char/sec - letter - 12 cpi , Up to 110 char/sec - letter - 10 cpi
Wired
Parallel, USB
Fonts Included
10 x bitmapped , 4 x scalable , 8 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Media Sizes
A3 (297 x 420 mm)
Max Sheets in Multi-Part Form
5
1 x parallel , 1 x USB
MTBF
20,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Limited warranty - 1 year
Sound Emission (Operating)
50 dBA
61.3 cm
37.5 cm
17.2 cm
9.5 kg
65P1 Epson LQ2090 Printer Ribbon In Stock £18.50
