Epson LabelWorks LW-400VP Label Printer
Quicklinx: 9KVVWS00 Mfr#: C51CB70130
The LW-400VP is straightforward to use and ideal for busy work environments away from the office. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favourite 50 label designs at any time.
The smart, black design helps keep the label maker free from smears and fingerprints, while its black rubber casing provides a protective barrier against scratches and drops. Its black sturdy carry case enables you to transport it easily and safely, and gives you room to take the AC adaptor and up to six tapes with you.
The LW-400VP minimises label margins, meaning you get more labels per tape, and Epson's nine-metre label tape offers economical refills. You don't need to replace tapes quite so often. Two four-metre label tapes are included to get you started – black text on standard white tape, 12mm wide, and black text on strong adhesive yellow tape, 9mm wide.
The label maker prints up to four lines and offers excellent versatility thanks to a large number of formats, symbols and font designs. You can see how your labels will look – even in darkness or bright sunlight – thanks to the LW-400VP's backlit LCD screen.
Epson LabelWorks LW-400VP - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
Portable
418 g
Max Media Size
Roll (1.8 cm)
Print Speed
Up to 6 mm/sec
Max Resolution (B&W)
180 dpi
Cutter
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, ITF
Fonts
Sans Serif, Gothic
Styles & Effects
Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, Mirror
4 line printing
Display Resolution
2 lines x 16 characters
Keyboard
QWERTY / 61 keys
Required 6 x AA type
Enclosure Colour
Black, green
17 cm x 11 cm x 5.6 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Enclosure Colour
Black, green
Printer
Print Speed
Up to 6 mm/sec
Built-in Devices
Preview screen, character keyboard
180 dpi
Fonts
Sans Serif, Gothic
Styles & Effects
4 line printing
Display Resolution
Cutter
Keyboard
QWERTY / 61 keys
Repeating Printing
9 copies
Barcodes
Media Handling
Max Media Size
Roll (1.8 cm)
Media Sizes
Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm)
Max Printing Width
9 mm
Max Printing Length
400 mm
Carrying case
Media Included
1 12 mm x 4 m black on white LC tape, 1 9 mm x 4 m black on yellow strong adhesive LC tape
Power adapter - external
2.555 Watt
Power Consumption Stand by / Sleep
0.18 Watt
AA type
Required Qty
6
Environmental Standards
ENERGY STAR
Limited warranty - 2 years - carry-in
17 cm
11 cm
5.6 cm
418 g
