Product
Brand
Epson LabelWorks LW-400 Mono Thermal Transfer Labelmaker
Quicklinx: 7XVWWS00 Mfr#: C51CB70060
With its ergonomic buttons and integrated keyboard, the LW-400 is straightforward to use. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favorite label designs at any time. Remaining tape can be checked via a window.
Straightforward to use
With its ergonomic buttons and integrated keyboard, the LW-400 is straightforward to use. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favourite 50 label designs at any time. Remaining tape can be checked via a window.
Versatile
The LW-400 prints up to four lines and offers excellent versatility with eight barcode standards, 14 fonts, five character sizes, 487 symbols, 87 borders and 10 styles, including bold, italic, outline and shadow. See how your labels will look - even in darkness or sunlight - thanks to the LW-400's backlit LCD screen.
Flexible tape options
Epson's wide selection of labels in 6, 9, 12 and 18mm sizes cover virtually every labelling need. The range includes standard, black, transparent and writable matte paper labels, a variety of colours such as fluorescent and pastel, and two adhesive strengths. All Epson labels are durable, resisting water and withstanding hot and cold conditions.
Economical
The LW-400 minimises label margins, meaning you get more labels per tape, and Epson's 9-metre label tape offers economical refills. Two four-metre label tapes are included to get you started.
Backlit screen
For all light conditions
Flexible formatting
Choice of fonts, styles and borders
Choice of tapes
6, 9, 12 and 18mm labels
Store 50 designs
Create and save custom designs
9-metre tapes
For economical refills
Epson LabelWorks LW-400 - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
Portable
420 g
Max Media Size
Roll (1.8 cm)
Print Speed
Up to 6 mm/sec
Max Resolution (B&W)
180 dpi
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, ITF
Fonts
Sans Serif, Gothic
Styles & Effects
Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, Mirror
4 line printing
Display Resolution
2 lines x 16 characters
Keyboard
61 keys
Required 6 x AAA type
2 years warranty
11 cm x 17 cm x 5.6 cm
Printer Type
Printer
Print Speed
Up to 6 mm/sec
Built-in Devices
Preview screen, character keyboard, cutter
180 dpi
Fonts
Sans Serif, Gothic
Styles & Effects
4 line printing
Display Resolution
Keyboard
61 keys
Repeating Printing
9 copies
Barcodes
Media Handling
Max Media Size
Roll (1.8 cm)
Media Sizes
Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm)
Max Printing Width
9 mm
Max Printing Length
400 mm
Power adapter - external
2.26 Watt
Power Consumption Stand by / Sleep
0.18 Watt
AAA type
Required Qty
6
Environmental Standards
ENERGY STAR
11 cm
17 cm
5.6 cm
420 g
