Epson Kodak ESP C110 All-in-One Printer
Quicklinx: 7JYMWS00 Mfr#: 3953858
Looking for an affordable, easy to use all-in-one printer that uses high-quality, low-cost ink cartridges? Check out the Kodak ESP C110 All-in-One Printer. The C110 delivers crisp, sharp text documents, brilliant graphics, and Kodak lab-quality photos that dry instantly and last a lifetime. With Kodak it's never been easier to put high-quality home printing within your means.
The Perfect Page technology improves the quality of your scanned document even when your original is less than perfect. The KODACOLOR technology provides quality, speed, and longevity in one printing system without compromise.
Scan multiple pictures simultaneously - software creates separate files automatically. Intelligent paper sensor automatically adjusts printer settings based on paper type so you get the right print the first time.
View and print photos without a computer using the 3.8 cm (1.5") color display and media card slot. Easily access printable template designs right from the control panel including graph paper, line paper, tic-tac-toe, reminder list, shopping list, and sheet music.
Uncompromising quality at an unbelievable value
Looking for an affordable, easy to use all-in-one printer that uses high-quality, low-cost ink cartridges? Check out the KODAK ESP C110 All-in-One Printer. The C110 features a rear feed paper tray, 3.8 cm (1.5 in.) color LCD and media card slot. The C110 works with our expanded line of KODAK Pigment-Based 30 Series Inks. KODAK Pigment-Based Inks continue to offer the lowest ink replacement cost in the industry. Like all KODAK All-in-One Printers, the C110 delivers crisp, sharp text documents, brilliant graphics, and KODAK Lab-Quality Photos that dry instantly and last a lifetime. With Kodak it's never been easier to put high-quality home printing within your means.
High-quality photos and documents
-Create KODAK Lab-Quality Photos that last a lifetime
-Print sharp black text and brilliant color documents
-Perfect Page Technology--improves the quality of your scanned document even when your original is less than perfect
-KODACOLOR Technology, backed by 100+ years of KODAK Image Science, provides quality, speed, and longevity in one printing system--without compromise
-Low-cost, high-quality pigment-based inks and porous KODAK Inkjet Papers dry instantly, are water and fade resistant
-With KODAK All-in-One Home Center Software you can edit with ease to reduce red eye, fix blemishes and skin tones, or even restore color
Intuitive easy-to-use features
-Scan multiple pictures simultaneously--software creates separate files automatically
-Uses the new sort feature to easily find and view pictures on your memory card by month, day, or year on the printer LCD
-Rear feed paper tray holds 100 sheets of document paper or 20 sheets of photo paper for continuous, worry-free printing
-Intelligent paper sensor automatically adjusts printer settings based on paper type so you get the right print the first time
-Connect to a PC via USB cable with the built-in rear USB port
More control
-One-touch print, copy, scan functionality
-View and print photos without a computer using the 3.8 cm (1.5 in.) color display and media card slot--supports SD/SDHC, MMC, and MEMORY STICK
-Easily access printable template designs right from the control panel including graph paper, line paper (narrow or wide ruled), tic-tac-toe, reminder list, shopping list, and sheet music (portrait and landscape)
Eco-highlights
-Intelligent paper handling and image processing systems help reduce the need to reprint, ultimately reducing paper waste
-ENERGY STAR qualified
-Uses less energy--up to 71% less energy while in standby mode than previous KODAK AiO Printers
-KODAK Photo Papers are forest management scheme accredited through the Program for the Endorsement of Forest Certification (PEFC)--this is a sign that KODAK Papers are derived from forests that are managed in an environmentally responsible way backed by a rigorous third-party certification audit
  • High-quality photos and documents
    Create Kodak lab-quality photos that last a lifetime. Print sharp black text and brilliant color documents. The Perfect Page technology improves the quality of your scanned document even when your original is less than perfect. The KODACOLOR technology provides quality, speed, and longevity in one printing system without compromise.
  • Intuitive easy-to-use features
  • More control
  • Eco-highlights
    Intelligent paper handling and image processing systems help reduce the need to reprint, ultimately reducing paper waste.
Kodak ESP C110 All-in-One - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Max Copying Speed
Up to 5 ppm (mono) / up to 3 ppm (colour)
Max Printing Speed
Up to 6 ipm (mono) / up to 4 ipm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 9600 dpi (colour)
Scanning
1200 dpi
Display
1.5"
Original Size
Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB 2.0
Office Machine Features
Print from memory card
41.9 cm x 31.2 cm x 17.3 cm
5.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour - photo
Display Diagonal Size
1.5"
USB 2.0
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
500%
Max Document Reduction
20%
Maximum Copies
99
Copying Features
BorderFree
Printing
Max Printing Speed
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Interpolated Resolution
9600 dpi
Document & Media Handling
Max Original Size
Max Media Size
A4/Legal
Supported Media Type
100 sheets
Input tray - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 6 ipm - B/W , Printing: up to 4 ipm - colour , Printing: (10 x 15 cm (4"x6")) - photo , Copying: up to 5 ppm - B/W , Copying: up to 3 ppm - colour
1 x USB 2.0
Operating System Support
MS Windows 7, MS Windows XP Home Edition SP2 or later, MS Windows Vista Home Basic
Software Included
Drivers & Utilities
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (colour)
ENERGY STAR Certified
Limited warranty - 1 year
41.9 cm
31.2 cm
17.3 cm
5.4 kg
