Epson GT-2500N
Epson GT-2500N
Quicklinx: 4BHFWS00 Mfr#: B11B181021BU
The Epson GT-2500N is the ultimate business scanner – with the latest technology at an affordable price.
An affordable price doesn’t mean a compromise on quality or speed with this machine - documents can be scanned at up to 27ppm using the 2 pass duplex. And it converts proposals, quotes, letters, faxes and more into electronic files so you’re able to archive and share them with colleagues in minutes - increasing your office productivity.
What’s more, with a no maintenance Auto Document Feeder, the Epson GT-2500N lasts much longer than other models, so it will support your business for years to come.
  • Professional A4 scanning for the most demanding business
    This professional but affordable A4 office scanner has three options so it can match the way your business works and meet the demands of your office.
Epson GT 2500N - flatbed scanner - desktop - USB 2.0, LAN
Flatbed scanner - desktop
Interface Type
USB 2.0, LAN
Scanning Sensor Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
Optical Resolution
1200 dpi x 1200 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
AC 230V (50/60 Hz)
Microsoft Windows Millennium Edition, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.2 or later, Microsoft Windows XP Professional x64 Edition
Microsoft Certification
Certified for Windows Vista
46.8 cm x 39.5 cm x 20 cm
10 kg
1-year warranty
Interface Type
USB 2.0, LAN
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
1200 dpi x 1200 dpi
9600 dpi x 9600 dpi
CCD
Bulb / Light Source Type
Control Panel Buttons Functions
Scan
Scanner Speed Details
0.4 ms/line - black & white - 300 dpi , 1.2 ms/line - colour - 300 dpi , 0.8 ms/line - black & white - 600 dpi , 2.5 ms/line - colour - 600 dpi
TWAIN
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper
Automatic
Interfaces Details
USB 2.0 - Type B , LAN
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Internal power supply
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
43 Watt (15 Watt)
Software Included
Drivers & Utilities, EPSON Scan
46.8 cm
39.5 cm
20 cm
10 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Resources
The following resources are available for the Epson GT-2500N
