Epson GT-20000N Pro A3 Scanner
Quicklinx: 54KDWS00 Mfr#: B11B195021NA
Give your business the extra flexibility of A3 scanning with the Epson GT-20000N Pro. The 100 page auto document feeder works for you at up to 23 ppm and even scans both sides of the page. Share this high performance across your office and increase productivity with built-in networking. Now you can print, share and archive in a bigger way.
High performance scanning
Transform your office documents with fast, high quality scanning. From text to photos and from one-off pages to multi-page documents, make the most of your originals.
Free up your time
Digitise multiple pages quickly with the 100 page auto document feeder at up to 23 ppm mono and 15 ppm colour, leaving you to get on with other jobs. The duplex feature means you can even scan double-sided originals.
Share with the office
Everyone can access the Epson GT-20000N Pro on your network to make a centralised scanning resource. With TWAIN and ISIS driver support it also fits into your office document management system.
  • High performance scanning
  • Free up your time
Epson GT 20000N Pro - flatbed scanner - desktop - SCSI, LAN
Flatbed scanner - desktop
Interface Type
SCSI, LAN
Scanning Sensor Type
CCD
Light Source
Xenon gas fluorescent lamp
Max Supported Document Size
297 x 432 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 1200 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Size
297 mm x 432 mm
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.2.8 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
65.6 cm x 45.8 cm x 29.2 cm
26.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
SCSI, LAN
297 x 432 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 1200 dpi
9600 dpi x 9600 dpi
CCD
Bulb / Light Source Type
Scanner Speed Details
23 sec/scan - black & white - A4 - 200 dpi , 15 sec/scan - colour - A4 - 200 dpi , 13 sec/scan - black & white - A3 - 200 dpi , 8.6 sec/scan - colour - A3 - 200 dpi , 16 sec/scan - duplex - black & white - A4 - 200 dpi , 11 sec/scan - duplex - colour - A4 - 200 dpi , 12 sec/scan - duplex - black & white - A3 - 200 dpi , 8 sec/scan - duplex - colour - A3 - 200 dpi
TWAIN, ISIS
Media Handling
Max Document Size
297 mm x 432 mm
Automatic
100 sheets
Interfaces Details
USB 2.0 - Type B , SCSI - HD-50 , SCSI - HD-50 , LAN
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
50 Watt (6.2 Watt)
Software Included
ABBYY Finereader 6 Sprint, Presto! PageManager 7.0, EPSON Scan 3.4
65.6 cm
45.8 cm
29.2 cm
26.5 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Resources
The following resources are available for the Epson GT-20000N Pro A3 Scanner
