Give your business the extra flexibility of A3 scanning with the Epson GT-20000N Pro. The 100 page auto document feeder works for you at up to 23 ppm and even scans both sides of the page. Share this high performance across your office and increase productivity with built-in networking. Now you can print, share and archive in a bigger way.
High performance scanning
Transform your office documents with fast, high quality scanning. From text to photos and from one-off pages to multi-page documents, make the most of your originals.
Free up your time
Digitise multiple pages quickly with the 100 page auto document feeder at up to 23 ppm mono and 15 ppm colour, leaving you to get on with other jobs. The duplex feature means you can even scan double-sided originals.
Share with the office
Everyone can access the Epson GT-20000N Pro on your network to make a centralised scanning resource. With TWAIN and ISIS driver support it also fits into your office document management system.
Transform your office documents with fast, high quality scanning. From text to photos and from one-off pages to multi-page documents, make the most of your originals. -
Free up your time
- Epson GT 20000N Pro - flatbed scanner - desktop - SCSI, LAN
- Flatbed scanner - desktop
- Interface Type
- SCSI, LAN
- Scanning Sensor Type
- CCD
- Light Source
- Xenon gas fluorescent lamp
- Max Supported Document Size
- 297 x 432 mm
- Localisation
- United Kingdom
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 1200 dpi
- Interpolated Resolution
- 9600 dpi x 9600 dpi
- Max Document Size
- 297 mm x 432 mm
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 100 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.2.8 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista
- Microsoft Certification
- Certified for Windows Vista
- 65.6 cm x 45.8 cm x 29.2 cm
- 26.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- SCSI, LAN
- 297 x 432 mm
- Localisation
- United Kingdom
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- CCD
- Bulb / Light Source Type
- Scanner Speed Details
- 23 sec/scan - black & white - A4 - 200 dpi , 15 sec/scan - colour - A4 - 200 dpi , 13 sec/scan - black & white - A3 - 200 dpi , 8.6 sec/scan - colour - A3 - 200 dpi , 16 sec/scan - duplex - black & white - A4 - 200 dpi , 11 sec/scan - duplex - colour - A4 - 200 dpi , 12 sec/scan - duplex - black & white - A3 - 200 dpi , 8 sec/scan - duplex - colour - A3 - 200 dpi
- TWAIN, ISIS
Media Handling
- Max Document Size
- 297 mm x 432 mm
- Automatic
- 100 sheets
- Interfaces Details
- USB 2.0 - Type B , SCSI - HD-50 , SCSI - HD-50 , LAN
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 50 Watt (6.2 Watt)
- Software Included
- ABBYY Finereader 6 Sprint, Presto! PageManager 7.0, EPSON Scan 3.4
- OS Required
- 65.6 cm
- 45.8 cm
- 29.2 cm
- 26.5 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 10 - 80%
