Epson GT-20000 A3 Scanner
Quicklinx: 54KCWS00 Mfr#: B11B195021BY
High performance scanning
Transform office scanning with fast, high quality scanning on a big scale. From text to photos, make the most of all your originals with features including RGB dropout, auto-de-skew and text enhancement.
Fits right in
Incorporate the scanner into your office document management system driver support and transfer data quickly with USB 2.0 and SCSI connection.
Upgrade with your business
Scan larger archives up to 23 ppm with the optional 100 page duplexing auto document feeder and use optional networking to share great scanning across your office.
  • A3 business scanner
    With fast scanning up at A3 size, the high performance Epson GT-20000 handles all your business documents in a big way.
Epson GT 20000 - flatbed scanner - desktop - USB 2.0, SCSI
Flatbed scanner - desktop
Interface Type
USB 2.0, SCSI
Scanning Sensor Type
CCD
Light Source
Xenon gas fluorescent lamp
Max Supported Document Size
297 x 432 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 1200 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Size
297 mm x 432 mm
Document Feeder Type
Manual
Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.2.8 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
65.6 cm x 45.8 cm x 15.8 cm
13.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0, SCSI
297 x 432 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 1200 dpi
9600 dpi x 9600 dpi
CCD
Bulb / Light Source Type
Scanner Speed Details
4.3 sec/scan - black & white - A4 - 200 dpi , 6.1 sec/scan - colour - A4 - 200 dpi , 5.5 sec/scan - black & white - A3 - 200 dpi , 8.2 sec/scan - colour - A3 - 200 dpi
TWAIN, ISIS
Media Handling
Max Document Size
297 mm x 432 mm
Manual
Slots
Expansion slot
Interfaces Details
USB 2.0 - Type B , SCSI - HD-50 , SCSI - HD-50
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
50 Watt (6.2 Watt)
Software Included
ABBYY Finereader 6 Sprint, Presto! PageManager 7.0, EPSON Scan 3.4
65.6 cm
45.8 cm
15.8 cm
13.5 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Resources
The following resources are available for the Epson GT-20000 A3 Scanner
