Epson GT-1500 A4 Scanner
Quicklinx: 54WTWS00 Mfr#: B11B190021BA
Quick work:
Work fast with speeds up to 18 ppm in mono and 12 ppm in colour. Make the whole process one-touch simple by customising the controls for scanning to any folder or application.
Save energy:
With Epson ReadyScan LED technology you can start work as soon as you turn on, and you’ll make less of an impact on the environment because the scanner uses a lot less energy.
A perfect match:
With TWAIN/ISIS support this scanner is an easy fit with your document management system. Epson Event Manager is part of a software package that smooths the whole scanning process.
  • Affordable document scanner
    Put an end to paperwork overload: This personal business scanner works at up to 18 ppm and includes a 40-sheet auto document feeder.
Epson GT 1500 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
White LED
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
Optical Resolution
1200 dpi x 2400 dpi
Interpolated Resolution
4800 dpi x 4800 dpi
Max Document Size
216 mm x 297 mm
Document Feeder Type
Automatic
Document Storage Capacity
40 sheets
AC 230V (50/60 Hz)
Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.2.8 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
47 cm x 31.8 cm x 12.1 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
1200 dpi x 2400 dpi
4800 dpi x 4800 dpi
CCD
Bulb / Light Source Type
White LED
Control Panel Buttons Functions
Scan
Scanner Speed Details
18 ppm - black & white - A4 - 200 dpi , 18 ppm - greyscale - A4 - 200 dpi , 12 ppm - colour - A4 - 200 dpi
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 297 mm
Automatic
40 sheets
Slots
Expansion slot
Interfaces Details
USB 2.0 - Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, UL 60950-1, EN 60950-1
ENERGY STAR Certified
Internal power supply
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
12.5 Watt (2.3 Watt)
Software Included
ABBYY FineReader 5.0 Sprint Plus, ABBYY FineReader 6.0 Sprint Plus, EPSON Event Manager 2.0, Presto! PageManager 8
47 cm
31.8 cm
12.1 cm
3.9 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Resources
The following resources are available for the Epson GT-1500 A4 Scanner
