Epson FX 890II Monochrome Dot-Matrix Printer
Quicklinx: D8TRWS00 Mfr#: C11CF37402
The Epson FX-890II Series offers the durability and ease of use for critical daily print requirements. These reliable 9-pin, narrow-carriage impact printers boast a long life cycle, and high speeds. Their ribbon cartridge reduces user interventions as well as cost per page. Ideal for harsh environments, these workhorses race through cut-sheet, continuous or multipart forms up to 7 pages thick, and feature an intuitive control panel for easy setup and operation.
  • Higher print speeds
    The FX-890II offers an improved USD (ultra speed draft) speed of 735 characters per second at 12 characters per inch, making a real difference to high-volume print runs such as stock reports and large batches of invoices or freight documents.
  • Outstanding reliability
    Epson's dot matrix technology is already mature and very reliable, and this printer improves the mean time between failure by 25% to 25,000 power-on hours, ideal for challenging conditions or where regular maintenance is not practical.
  • Smaller footprint
    The dot matrix printer has a refreshed design with a smaller footprint - depth has been reduced to just 320 mm - making it easy to place into a business environment.
Epson FX 890II - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - B/W
7.2 kg
Max Media Size
Roll (21.6 cm), JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Print Speed
Up to 738 char/sec - ultra high speed draft , Up to 615 char/sec - ultra high speed draft , Up to 694 char/sec - high speed draft , Up to 612 char/sec - high speed draft , Up to 555 char/sec - draft , Up to 463 char/sec - draft , Up to 138 char/sec - letter , Up to 115 char/sec - letter
Max Resolution (B&W)
240 x 144 dpi
Parallel, USB 2.0
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P, IBM PPDS
Barcodes
Matrix 2 of 5, Industrial 2 of 5, Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, plain paper, continuous forms
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016
41.4 cm x 32 cm x 17.65 cm
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
Print Speed
Up to 738 char/sec - ultra high speed draft - 12 cpi , Up to 615 char/sec - ultra high speed draft - 10 cpi , Up to 694 char/sec - high speed draft - 12 dpi , Up to 612 char/sec - high speed draft - 10 cpi , Up to 555 char/sec - draft - 12 cpi , Up to 463 char/sec - draft - 10 cpi , Up to 138 char/sec - letter - 12 cpi , Up to 115 char/sec - letter - 10 cpi
Wired
Parallel, USB 2.0
240 x 144 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
Media Sizes
Roll (21.6 cm), JIS B4 (257 x 364 mm), 100 x 100 mm, continuous paper 101.6 mm - 254 mm (width)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), US No 6 (92 x 165 mm)
Media Thickness Range
0.06 mm - 0.46 mm
Max Sheets in Multi-Part Form
6
1 x USB 2.0 , 1 x parallel
Consumables Included
1 x printhead - up to 400 million characters , 1 x ribbon (black) - up to 7.5 million characters
MTBF
25,000 hour(s)
EMC, ICES-003 Class A, UL 60950-1, FCC Part 15 B Class A, CAN/CSA-C22.2 No. 60950-1
Power supply - internal
Frequency Required
50 - 60 Hz
54 Watt
Power Consumption Stand by
8 Watt
Power Consumption Sleep
0.8 Watt
Environmental Standards
ENERGY STAR
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
55 dBA
41.4 cm
32 cm
17.65 cm
7.2 kg
D8TR Epson FC-890 Ribbon Cartridge In Stock £4.59
