Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use
A 10.9cm interactive LCD touch-screen makes navigation and printing directly from memory card quick and simple. For even easier operation, a motorised control panel and output tray mean hassle-free printing.
Advanced control
Easily switch between photo and A4-sized prints with two front-loading paper trays. Print onto thicker media using the rear speciality media feed and enjoy fast and easy double-sided copying, scanning and faxing with the ADF. You can also directly print onto suitable CDs/DVDs.
Versatile Wi-Fi 4-in-1
Advanced 4-in-1 printer with duplex that produces outstanding glossy photos and documents and comes with a range of easy-to-use features.
- Epson Expression Premium XP-830 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 5-ink
- Max Printing Speed
- Up to 14 ppm (mono) / up to 11 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 4800 x 4800 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 120 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud
- Power
- AC 230 V (50/60Hz)
- 39 cm x 33.9 cm x 19.1 cm
- 8.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Copying
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (per cartridge)
- Ink Cartridge Configuration
- 5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, photo black
- 5-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson Claria Premium Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 4800 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 180 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 60 station(s)
- Automatic redialing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 90 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 120 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm) , ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 95 g/m² , Photo tray - 20 sheets
- Speed Details
- Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 14 ppm - B/W (ISO/IEC 24734) , Printing: up to 11 ppm - colour (ISO/IEC 24734) , Printing: 12 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.6.8 or later, Windows 8
- Software Included
- Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print, Epson Fax Utility
- Voltage Required
- 20 Watt
- Power Consumption Sleep
- 1.6 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
- CISPR 22 Class B, FCC Part 15 B, UL 60950-1, CAN/CSA-C22.2 No. 60950-1
- 39 cm
- 33.9 cm
- 19.1 cm
- 8.2 kg
Epson A4 Iron On Transfer Pack 10sht | In Stock | £14.64 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.42 |
