Epson Expression Premium XP-630 Colour Inkjet Multifunction Printer
Quicklinx: BMFWWS00 Mfr#: C11CE79401
Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge. The use of individual ink cartridges means only the colour used need to be replaced to help save on ink costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use features
For maximum control, the XP-630 comes with a tilting control panel and 6.8cm LCD screen with touchpad for easy navigation. Dual paper trays, one for A4 and one for photo paper, and fast, double-sided printing helps save time. Users can also simply slot in a memory card and follow the helpful menu prompts to print photos without a PC.
  • Effortless connectivity
    With options like AirPrint, Google Cloud Print, and Wi-Fi Direct, the Epson Expression Premium XP-630 ensures seamless connection across all your devices, making it easier than ever to print from anywhere.
  • Versatile media handling
    From envelopes to photo paper, the XP-630 is designed to support a wide range of media types and sizes, including A4, Legal, and more, catering to all your printing needs.
  • High-quality printing
    Achieve high-quality print quality with a maximum resolution of 5760 x 1440 DPI for both black and color prints, and enjoy the richness of photos printed with Epson Claria Premium Ink.
  • Convenient scanning and copying
    With a high optical resolution of 1200 x 2400 DPI and versatile functions like printing from and saving to USB flash drives and memory cards, the XP-630 offers comprehensive scanning and copying solutions.
  • Eco-friendly choice
    The ENERGY STAR certification of the XP-630 assures you of its energy efficiency, making it an environmentally friendly addition to your home or office.
Epson Expression Premium XP-630 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 13 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive
AC 230 V
39 cm x 34.1 cm x 13.8 cm
6.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
360 nozzles (black), 180 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, photo black
4-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets , CD/DVD tray
Speed Details
Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
1 x USB , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, MS Windows XP (32/64 bits)
Software Included
Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print
AC 230 V
18 Watt
Power Consumption Standby
1.2 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
ENERGY STAR Certified
39 cm
34.1 cm
13.8 cm
6.7 kg
Sound Emission
37 dBA (operating)
BMFW Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £15.06
BMFW Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.57
BMFW Epson A4 Iron On Transfer Pack 10sht In Stock £13.31
BMFW Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.57
BMFW Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.94
