Epson Expression Photo XP-950 Colour Inkjet Multifunction Printer
Quicklinx: 8WZZWS00 Mfr#: C11CD28301
Media flexibility and A3 photos
With two front-loading paper trays, you can switch between photo and A4-sized prints without having to reload the media, while the rear speciality media feed enables you to print onto a variety of media up to A3. In addition you can print directly onto suitable CDs and DVDs.
Claria Photo HD Ink
Epson's six-colour Claria Photo HD Ink is ideal if you are looking to produce superior-quality, long-lasting photographs, as it delivers smooth tonal gradations, deep natural blacks and rich, vibrant colours.
Epson Connect and mobile printing
The Expression Photo XP-950 comes with Epson Connect , which allows you to quickly and easily print documents and photos over Wi-Fi from smartphones, and tablets. You can also print from anywhere in the world by emailing documents and photos directly to the printer, while Scan-to-Cloud enables you to store scanned documents directly in cloud services.
It is also compatible with Google Cloud Print.
Wi-Fi Direct
This allows you to print from wireless devices without having to connect to a wireless router.
PC-free printing
The 8.8cm touch-sensitive screen has a user-friendly interactive menu for PC-free photo printing from memory cards and PictBridge. You can scroll through the menu with a swipe of a finger, similar to smartphone screen technology.
  • A photographer's best friend
    The Expression Photo XP-950 is an ultra-compact printer that offers all the high-end features usually found in an Epson photo all-in-one but with the added ability to print high-quality A3 photos.
  • Introducing the Expression Photo XP-950
    Ultra-compact printing of large, beautifully detailed photographs is what the cleverly designed XP-950 is all about. It has a footprint more typical of an A4 printer, but its compact design can issue fabulously detailed A3-sized prints and photos. It's well-armed to achieve perfection, with the six-colour Claria Photo HD Ink, a dedicated photo paper tray and a speciality rear media feed for A3-sized paper or card.The combination of A3 photos and its ability to not only print but also scan and copy, make this a true one-off. It's what's inside that makes the XP-950 stand out; from the inks to the printhead, all elements are designed by us and created to work in harmony. The results are great looking, long-lasting prints that photographers will be proud to display and share.It's not all about photography.It may be a cutting-edge A3 printer, but the XP-950 has all the familiar features, too. Fitted with WiFi for easy set-up and a large touchscreen that's simple to use, the XP-950 uses two front-loading paper trays for easy switching between media and sizes. It couldn't be easier, and the results are hard to beat.
  • True photographic quality
    Great photos should look even better when printed, and that's exactly what the XP-950 promises for owners of DSLR and compact cameras. It uses Epson's top-of-the-range six-colour Claria Photo HD Ink, a dye-based ink set that creates superior-quality, long-lasting photos dominated by detail, high contrast and smooth natural skin tones, and is ideal for keen photographers.Claria Photo HD Ink delivers smooth tonal gradations, deep natural blacks and rich, vibrant colours. This six-colour ink set features the standard CMYK inks, as well as Light Cyan and Light Magenta inks, to create an extensive colour gamut.With individual ink cartridges you only have to replace the colour used, saving you money. Claria Photo HD Ink cartridges are available in standard and XL sizes, with page yields displayed clearly on each pack to aid your purchasing decision. And what's more, identifying the right ink cartridge for your printer couldn't be simpler – just look out for the Elephant image.
  • Stay Connected – send your creations to print immediately
    A multifunction device with its own email address to print from a smartphone or tablet, the XP-950 can print even from the cloud.The XP-950 has its own email address, so you can take a photo anywhere in the world and email it back home – or to another Epson printer owned by family, friends or a colleague. It works the other way, too; add someone's email address to your list of Approved Senders and they can print photos or documents straight to your XP-950.And, when you're away from home using a computer that's connected to the internet, the Remote Print Driver makes it easy to print straight to the XP-950, so your photos and documents are waiting for you.And there are even more ways to share photos using Epson Connect, as it's compatible with Google Cloud Print. By linking the XP-950 to accounts on popular cloud storage websites like Dropbox, Google Drive, Box or Evernote, you can scan photos and documents directly to them. Used with desktop or laptop computers, smartphones, tablets or over WiFi, a compact printer has never been so flexible.
  • Ditch the desktop
    The XP-950 isn't just for desktop computer owners – download the free Epson iPrint app to a smartphone or tablet and scan to it or you can print web pages, photos and documents stored either on that device or in the cloud.You are in total control – as long as you have a WiFi connection. It puts the fun back into photography; if you're in your garden and take a great photo of family or friends with your smartphone, why not print it out immediately to share?It's clever yet simple, allowing you to crop or delete images, choose the layout, the print quality and the number of copies you want.
  • Media flexibility
    The XP-950 features two front-loading paper trays so you can switch between common photo media such as 10x15cm, or A4 sized paper, while the rear speciality media feed can hold paper or card of up to A3 in size for truly versatile printing.It prints on suitable CDs and DVDs to personalise films and create smart digital photo albums, and it can also print direct from a camera's memory card. It's also compatible with PictBridge, so you can print directly from a wide range of devices.
  • Easy-to-use
    The 8.8cm touch-screen features a user-friendly interactive menu, for straight-forward, easy-to-operate PC-free photo printing. You can scroll through the with a simple swipe of your finger, similar to smartphone screen technology.This printer also features a motorised control panel, which automatically opens and moves into position to give easier access to the controls. At the same time, it extends the output tray that collects printouts neatly without manual operation.
  • Who needs cables?
    No one wants to spend time with cables and manuals setting-up a printer, which is why the user-friendly XP-950 comes with Auto WiFi setup, which configures the settings for you quickly and securely, without having to key in any passwords.With WiFi Direct also included, it's easy to print photos or documents stored on smartphones or tablets even without the XP-950 on a home WiFi network. Able to make a direct link to your mobile device in seconds, the XP-950 can print off photos taken just moments ago, without the need for cables or cards.
  • Save paper, save money
    Save paper and reduce your carbon footprint. Able to print on both sides of the paper – or duplex – the XP-950 instantly cuts your paper usage in half. After all, while we all find paper documents handy to refer to, no one wants to carry around any more paper than they absolutely have to either. And, of course, this has the added bonus of saving you money too.
  • Print from Facebook and more
    If you're anything like us, many of your best photos will be stored on Facebook. Step forward Epson Creative Print, an app that can fetch snaps you've previously uploaded and print them on the XP-950. However, that's just the beginning; Epson Creative Print gives you the ability to print personalised greetings cards, colouring book pages, stationery and even onto CDs and DVDs.
Epson Expression Photo XP-950 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 6-ink
Max Printing Speed
Up to 8.5 ppm (mono) / up to 8 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
4800 x 4800 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A3 (297 x 420 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD disc
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card
AC 230 V
47.9 cm x 35.6 cm x 14.8 cm
8.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
SD Memory Card, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
6 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, light cyan, light magenta
6-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Photo HD Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
4800 x 4800 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A3
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - A3 (297 x 420 mm)
Speed Details
Printing: up to 8.5 ppm - B/W (ISO/IEC 24734) , Printing: up to 8 ppm - colour (ISO/IEC 24734) , Printing: up to 28 ppm - B/W , Printing: up to 28 ppm - colour , Printing: 11 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.5.8 or later, Windows 8
Software Included
Epson Event Manager, EPSON Print CD, Epson Easy Photo Print, ArcSoft Scan-n-Stitch Deluxe
AC 230 V
21 Watt
Power Consumption Sleep
1.4 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta)
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
47.9 cm
35.6 cm
14.8 cm
8.8 kg
Shipping Width
57.8 cm
Shipping Depth
23.9 cm
Shipping Height
45.9 cm
Shipping Weight
11 kg
Sound Emission
37 dBA (operating)
8WZZ Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.98
8WZZ Epson A4 Iron On Transfer Pack 10sht In Stock £14.71
8WZZ Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.98
8WZZ Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.48
