The Expression Photo XP-8700 is great if you're looking for an A4 printer that can cater for both everyday printing and producing superior, glossy photographs. Making everyday tasks easy, it includes mobile printing, a large touchscreen and dual paper trays.
Compact multifunction printer
Show off your photos to their very best with this A4 multifunction printer, that's designed to complement your home with its compact and stylish design. -
User-friendly and versatile
Access photos directly via the memory card slot using the large 10.9cm touchscreen. It's easy to switch between tasks with the two front-loading paper trays (A4 and photo-sized) and a rear speciality media feed for thicker media. You can print onto suitable CDs and DVDs, and it also benefits from a motorised output tray, auto power on and A4 double-sided printing. -
Flexible wireless solutions
Print, scan and more, directly from your phone or tablet using the Epson Smart Panel app. Plus, with the Epson Creative Print app, you can use your photos to create and print photo books, greeting cards, collages and more. -
Claria Photo HD Inks
Print professional, glossy photos with Claria Photo HD Inks. Photography enthusiasts and semi-professionals will appreciate the quality produced by its 6-colour, individual inks. Designed with longevity in mind, photos will last up to 300 years in a photo album.
- Epson Expression Photo XP-8700 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 6-ink
- Max Printing Speed
- Up to 9.5 ppm (mono) / up to 9 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Printing Resolution Class
- Scanning
- 1200 x 4800 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, printable CD/DVD disc
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, red-eye correction, Photo Enhance
- Power
- AC 120/230 V (50/60Hz)
- 34.9 cm x 34 cm x 14.2 cm
- 6.8 kg
- Enclosure Colour
- Black
- 1-year warranty
- Ink-jet - colour
- Display Colour Support
- Display Features
- Touch screen
- Interface
- USB, Wi-Fi
- AirPrint Enabled
- Enclosure Colour
- Black
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (black), 180 nozzles (per colour)
- Ink Cartridge Configuration
- 6 cartridges (1 each: light cyan, light magenta, yellow, black, magenta, cyan)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, light cyan, light magenta
- 6-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson Claria Photo HD Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 4800 dpi
Document & Media Handling
- Supported Original Sizes
- A4 (210 x 297 mm)
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets , Photo tray - 20 sheets
- Speed Details
- Printing: up to 9.5 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 9 ppm (A4) - colour (ISO/IEC 24734) , Printing: up to 32 ppm - B/W (75 gsm plain paper) , Printing: up to 32 ppm - color (75 gsm plain paper) , Printing: 10 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB - 4 pin USB Type B
- WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
- Operating System Support
- MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows XP Professional x64 Edition SP2 or later
- Software Included
- EPSON Print CD, Epson Easy Photo Print, EPSON Scan 2
- Voltage Required
- 20 Watt
- Power Consumption Standby
- 7.2 Watt
- Power Consumption Sleep
- 0.7 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta)
- Limited warranty - 1 year - carry-in
- 34.9 cm
- 34 cm
- 14.2 cm
- 6.8 kg
- Shipping Width
- 21 cm
- Shipping Depth
- 48 cm
- Shipping Height
- 41.5 cm
- Shipping Weight
- 8.12 kg
Epson Singlepack Black 378 Claria Photo HD Ink | In Stock | £8.77 |
