Epson Expression Photo XP-8700 - Multifunction printer - colour -
Quicklinx: GVHYWS00 Mfr#: C11CK46401
Type: Printer / copier / scanner
Functionality: Printer, Scanner, Copier
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
40 In Stock
£143.15 ex VAT
£171.78 inc VAT
The Expression Photo XP-8700 is great if you're looking for an A4 printer that can cater for both everyday printing and producing superior, glossy photographs. Making everyday tasks easy, it includes mobile printing, a large touchscreen and dual paper trays.
  • Compact multifunction printer
    Show off your photos to their very best with this A4 multifunction printer, that's designed to complement your home with its compact and stylish design.
  • User-friendly and versatile
    Access photos directly via the memory card slot using the large 10.9cm touchscreen. It's easy to switch between tasks with the two front-loading paper trays (A4 and photo-sized) and a rear speciality media feed for thicker media. You can print onto suitable CDs and DVDs, and it also benefits from a motorised output tray, auto power on and A4 double-sided printing.
  • Flexible wireless solutions
    Print, scan and more, directly from your phone or tablet using the Epson Smart Panel app. Plus, with the Epson Creative Print app, you can use your photos to create and print photo books, greeting cards, collages and more.
  • Claria Photo HD Inks
    Print professional, glossy photos with Claria Photo HD Inks. Photography enthusiasts and semi-professionals will appreciate the quality produced by its 6-colour, individual inks. Designed with longevity in mind, photos will last up to 300 years in a photo album.
Epson Expression Photo XP-8700 - multifunction printer - colour
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 6-ink
Max Printing Speed
Up to 9.5 ppm (mono) / up to 9 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Printing Resolution Class
Scanning
1200 x 4800 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD disc
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from USB flash drive, red-eye correction, Photo Enhance
AC 120/230 V (50/60Hz)
34.9 cm x 34 cm x 14.2 cm
6.8 kg
Enclosure Colour
1-year warranty
Printing Technology
Ink-jet - colour
Display Colour Support
Display Features
Touch screen
USB, Wi-Fi
AirPrint Enabled
Enclosure Colour
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 180 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
6 cartridges (1 each: light cyan, light magenta, yellow, black, magenta, cyan)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, light cyan, light magenta
6-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Photo HD Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 4800 dpi
Document & Media Handling
Supported Original Sizes
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets , Photo tray - 20 sheets
Speed Details
Printing: up to 9.5 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 9 ppm (A4) - colour (ISO/IEC 24734) , Printing: up to 32 ppm - B/W (75 gsm plain paper) , Printing: up to 32 ppm - color (75 gsm plain paper) , Printing: 10 sec (10 x 15 cm (4"x6")) - photo
1 x USB - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
Operating System Support
MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows XP Professional x64 Edition SP2 or later
Software Included
EPSON Print CD, Epson Easy Photo Print, EPSON Scan 2
20 watt
Power Consumption Standby
7.2 watt
Power Consumption Sleep
0.7 watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta)
Limited warranty - 1 year - carry-in
34.9 cm
34 cm
14.2 cm
6.8 kg
Shipping Width
21 cm
Shipping Depth
48 cm
Shipping Height
41.5 cm
Shipping Weight
8.12 kg
GVHY Epson Singlepack Black 378 Claria Photo HD Ink In Stock £8.73
GVHY Epson Singlepack Cyan 378 Claria Photo HD Ink In Stock £9.09
GVHY Epson Singlepack Magenta 378 Claria Photo HD Ink In Stock £9.09
GVHY Epson Singlepack Yellow 378 Claria Photo HD Ink In Stock £9.09
Functionality: Scanner
Functionality: Copier
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Epson
