Compact yet feature rich
Surprisingly compact, the XP-15000 can print A3+ photos from its small footprint. It's stylish too and looks great from all angles.
Enhanced inks
Print long-lasting and professional-looking glossy photos with Claria Photo HD Inks. The set of six inks includes grey for superior black and white photos with a smoother tonal gradation, and red for vivid and realistic colours thanks to the wider colour gamut.
Print when and where you want
Printing photos and documents on the go is easy; simply download the free Epson iPrint app to print wirelessly from your smart device. The free Epson Creative Print app can print photos directly from Facebook, create greeting cards, turn photos into colouring books, and plenty more. You can even print by emailing files to the printer from almost anywhere in the world with Epson Email Print .
Flexible
Print wirelessly with or without a network using Wi-Fi and Wi-Fi Direct. There is also Ethernet for printing through a wired network. In addition, the auto power on feature activates the printer and automatically opens the output tray when a print job is sent.
Versatile
The front-loading paper tray can be used for paper up to A4, while the rear paper feed is suitable for up to A3+ including thicker media. You can also print A4 double-sided and on suitable CDs and DVDs.
Versatile Connectivity
With both LAN and wireless capabilities, this printer offers flexible connectivity options for easy integration into any home or office network. -
High-Quality Printing
Achieve professional-grade prints with a maximum resolution of 5760 x 1400 DPI, ensuring sharp, detailed images and crisp text on every page. -
Wide Media Support
From envelopes to A3 Plus photo paper, the Epson Expression Photo HD XP-15000 accommodates a variety of media sizes and types, making it ideal for diverse printing needs. -
Advanced Ink Technology
Featuring a 6 individual ink tank system with an extensive color palette including cyan, magenta, yellow, black, red, and gray, this printer delivers vibrant photos and clear documents. -
Efficient Printing Speeds
With printing speeds of up to 9.2 ppm for black and white and 9 ppm for color, this printer combines quality with efficiency to meet your printing demands.
- Epson Expression Photo HD XP-15000 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 8.5 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, black, red, grey
- Media Size Class
- A3
- Max Media Size
- A3 Plus (330.2 x 482.6 mm)
- Print Speed
- Up to 9.2 ppm - B/W (ISO/IEC 24734) , Up to 9 ppm - colour (ISO/IEC 24734) , Up to 29 ppm - B/W , Up to 29 ppm - colour
- Max Resolution (B&W)
- 5760 x 1400 dpi
- Max Resolution (Colour)
- 5760 x 1400 dpi
- Max Resolution Class (B&W)
- 5760 x 1400 dpi
- Max Resolution Class (Colour)
- 5760 x 1400 dpi
- Automatic Duplexing
- Print on CD/DVD
- Interface
- USB, LAN, Wi-Fi(n)
- Media Type
- Envelopes, plain paper, photo paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 200-sheet input tray, 50-sheet photo paper tray
- Networking
- Print server
- Printer Features
- Red eye reduction
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition SP2, Microsoft Windows XP SP3, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1, Windows 10
- 1-year warranty
- 47.6 cm x 37 cm x 15.9 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (per cartridge)
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Cartridge Configuration
- 6 individual ink tanks
- Ink Type
- Epson Claria Photo HD Ink
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 5760 x 1400 dpi
- 5760 x 1400 dpi
- 5760 x 1400 dpi
- 5760 x 1400 dpi
- Print on CD/DVD
- Direct Printing Specifications
- PictBridge
- Printer Features
- Red eye reduction
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm, A3 Plus (330.2 x 482.6 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 250 sheets
- Media Feeders
- Input tray: 1 x automatic - 200 sheets , Photo tray: 1 x automatic - 50 sheets
- Max Media Capacity
- 250 sheets
- Networking
- Print server
- WEP, WPA-PSK, Wi-Fi Direct
- Connections
- 1 x USB , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black) , 1 x ink cartridge (red) , 1 x ink cartridge (grey)
- Power Device
- Power supply - internal
- 21 Watt
- Power Consumption Stand by
- 5.7 Watt
- Power Consumption Sleep
- 0.8 Watt
- Software Included
- EPSON Print CD, EPSON Easy Photo Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - carry-in
- Sound Emission (Operating)
- 36 dBA
- 47.6 cm
- 37 cm
- 15.9 cm
- 8.5 kg
Epson Premium Glossy A4 Photo Paper 15 Sheets | In Stock | £12.84 |
Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) | In Stock | £12.84 |
Epson Premium Glossy Photo Paper - 30 Sheets | In Stock | £9.60 |
Epson Premium Glossy Photo Paper - 100 x 150 mm - 40 sheets | In Stock | £9.13 |
Epson Premium Glossy Photo Paper BOGOF - 100 x 150 mm - 255 g/m2 - 40 sheets (pack of 2 ) | In Stock | £9.13 |
Epson Ultra Glossy Photo Paper 10x15 50 Sheets | In Stock | £14.03 |
Epson A4 Glossy Photo Paper 20 Sheets | In Stock | £9.92 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £7.26 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.78 |
Epson Singlepack Black 378 Claria Photo HD Ink | In Stock | £8.73 |
Epson Singlepack Cyan 378 Claria Photo HD Ink | In Stock | £9.02 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.22 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £20.69 |
