Compact and versatile
Epson's Expression Premium XP-605 1 is perfect for home users who are interested in printing photos and need a Wi-Fi printer that can print glossy photos and crisp, clear text documents. This printer is an impressive 40 percent smaller than previous models. It also boasts intelligent features such as fast duplex printing, dual paper trays and Epson Connect - for versatile, user-friendly printing.
Claria premium ink produces crisp, clear text documents and outstanding, glossy photos with sharp detail, deep blacks and rich, vibrant colors. It offers a perfect balance for the modern home. Epson Connect allows you to print wirelessly from smartphones and tablet PCs within the home, and print from anywhere in the world by emailing documents directly to the printer's unique email address. The remote printer driver offers more flexibility to print from your PC to any Epson Connect printer anywhere in the world, while Scan-to-Cloud enables you to store scanned documents directly in cloud services. In addition the XP-605 is AirPrint and Google Cloud print ready.
Setting up the XP-605's Wi-Fi connection is easy with its automatic Wi-Fi set-up. The printer automatically finds the relevant connection settings in order to configure itself. Dual front-loading paper trays allow you to choose between photo and A4 printing. You can also fill both paper trays with photo paper to further increase your photo printing output.
The 6.3 cm color LCD screen with smart-navigation touch-panel highlights relevant buttons, guiding you through the printing process, while the PictBridge and memory card slots offer greater flexibility for PC-free photo printing. This printer will also print directly onto suitable CDs and DVDs so you can personalize family films and digital photo albums to create the ideal gift.
Wi-Fi all-in-one
Print, scan, copy
Ultra compact
40% smaller than previous models
Epson Connect
Freedom to print and scan anywhere
Easy operation
6.3cm smart-navigation LCD screen
Versatile
CD and DVD printing
- Epson Expression Premium XP-605 - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo
- Max Printing Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, printable CD/DVD disc
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, USB host, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from memory card
- Power
- AC 230 V (50/60Hz)
- 39 cm x 34.1 cm x 13.8 cm
- 7.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Ink-jet - colour
- Interface
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, Memory Stick Duo, MicroSDHC, Memory Stick Micro (M2), Memory Stick PRO Duo, MicroSD, SDHC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 360 nozzles (black), 180 nozzles (per colour)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, photo black
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson Claria Premium Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 12 ppm - B/W (ISO/IEC 24734) , Printing: up to 9 ppm - colour (ISO/IEC 24734)
- 1 x USB 2.0 , 1 x USB host
- WEP, WPA-PSK
- Operating System Support
- MS Windows XP, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.8 or later, MS Windows 8
- Software Included
- Epson Event Manager, EPSON Print CD, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac
- Voltage Required
- 18 Watt
- Power Consumption Sleep
- 2 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
- ENERGY STAR Certified
- Limited warranty - 1 year - carry-in
- 39 cm
- 34.1 cm
- 13.8 cm
- 7.1 kg
- Shipping Width
- 47.9 cm
- Shipping Depth
- 23.5 cm
- Shipping Height
- 42.7 cm
- Shipping Weight
- 9.4 kg
