Epson Expression Home XP-212  Colour Inkjet Multifunction Printer
Quicklinx: 8WZMWS00 Mfr#: C11CC94301
Epson's Small-in-One
The Expression Home XP-212 comes with Epson iPrint (1), offering greater flexibility and freedom. It allows you to quickly and easily print documents and photos over Wi-Fi from smartphones and tablet PCs.
The automatic Wi-Fi set-up (2) makes configuring laptops and computers to print and scan wirelessly extremely easy. You don't need to know your network settings, as the XP-212 automatically finds the relevant connection settings in order to configure itself.
Epson's Claria Home Ink is ideal for affordable reliable printing: producing crisp, clear text documents and glossy, lab-quality photos. With individual ink cartridges you only have to replace the colour used, saving you money.
Claria Home Ink cartridges are available in standard and XL sizes, with page yields displayed clearly on each pack. Identifying the right ink cartridge for your printer couldn't be simpler - just look out for the Daisy image.
Small-in-One
Save space, save money, save time
Epson iPrint
Mobile printing over Wi-Fi
Auto Wi-Fi
Easy to connect wirelessly
Individual Inks
Only replace the colour used
Claria Home Ink
Crisp, clear text and glossy photos
  1. Epson iPrint requires a wireless connection and the Epson printing app. For more information, supported languages and devices, please visit www.epsonconnect.eu
  2. Automatic set-up compatible with Windows 7, Windows Vista and Mac OS. Initial Wi-Fi set-up requires a USB cable for Windows XP users - not included
  • Small-in-one
    Save space, save money, save time.
  • Epson iPrint
    Mobile printing over Wi-Fi.
  • Auto Wi-Fi
    Easy to connect wirelessly.
  • Individual inks
    Only replace the color used.
  • Claria home ink
    Crisp, clear text and glossy photos.
Epson Expression Home XP-212 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 6.2 ppm (mono) / up to 3.1 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
50 sheets
Connection Availability
USB 2.0, Wi-Fi
AC 110/230 V (50/60Hz)
39 cm x 30 cm x 14.5 cm
3.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
USB 2.0, Wi-Fi
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
128 nozzles (black), 3 x 42 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson Claria Home Ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
50 sheets
Input tray - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 6.2 ppm - B/W (ISO/IEC 24734) , Printing: up to 3.1 ppm - colour (ISO/IEC 24734) , Printing: up to 26 ppm - B/W , Printing: up to 13 ppm - colour , Printing: 54 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPS
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.5.8 or later, Windows 8
Software Included
Epson Event Manager, Epson Easy Photo Print
12 Watt
Power Consumption Sleep
2.7 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
39 cm
30 cm
14.5 cm
3.9 kg
Shipping Width
46.6 cm
Shipping Depth
20.2 cm
Shipping Height
38.6 cm
Shipping Weight
5.1 kg
8WZM Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.51
8WZM Epson A4 Iron On Transfer Pack 10sht In Stock £14.60
8WZM Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.89
8WZM Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.36
8WZM Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £15.36
