Epson Expression Home XP-205 Inkjet All-in-One
Quicklinx: 8SGRWS00 Mfr#: C11CC49301
Wireless Small-in-One
The Epson Expression Home XP-205 comes with Epson Connect[1], offering even more flexibility and freedom. It allows users to quickly and easily print documents and photos wirelessly from smartphones and tablet PCs. Additionally, users can print from anywhere in the world by emailing documents and photos directly to the printer.
The XP-205 is Apple AirPrint ready and makes it simple to print emails, photos, web pages and documents directly from iOS devices[2].
Meanwhile, Google Cloud Print is also supported and allows users to print on the go from a smartphone or computer.
The automatic Wi-Fi set-up[3] makes configuring laptops and computers to print and scan wirelessly extremely easy. Users don't need to know their network settings or connect with a USB cable, the XP-205 automatically finds the relevant connection settings in order to configure itself.
Epson's new, Claria Home Ink is ideal for affordable reliable printing, producing crisp, clear text documents and glossy, lab-quality photos. With individual ink cartridges you only have to replace the colour used, saving you money.
Claria Home Ink cartridges are available in standard and XL sizes, with page yields displayed clearly on each pack. Identifying the right ink cartridge for your printer couldn't be simpler - just look out for the Daisy image.
Small-in-One
Save space, save money, save time
Epson Connect[1]
Mobile printing over Wi-Fi and email
Auto Wi-Fi set-up[3]
Easy to connect wirelessly
Individual Inks
Only replace the colour used
Claria Home Ink
Crisp, clear text and glossy photos
1 - Requires a wireless connection to the internet. For more information, supported languages and supported devices please visit www.epsonconnect.eu
2 - iOS 5 and above. AirPrint and the AirPrint logo are trademarks of Apple Inc
3 - Automatic set-up compatible with Windows 7, Windows Vista and Mac OS. Initial Wi-Fi set-up requires a USB cable for Windows XP users - not included This printer and original ink cartridges are for sale and use in EMEAR only.
Epson Expression Home XP-205 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 6.2 ppm (mono) / up to 3.1 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB 2.0, Wi-Fi
AirPrint Enabled
AC 110/230 V (50/60Hz)
39 cm x 30 cm x 14.5 cm
4.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Printing Technology
Ink-jet - colour
USB 2.0, Wi-Fi
AirPrint Enabled
Supported Flash Memory
Memory Stick
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
128 nozzles (black), 3 x 42 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson Claria Home Ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 6.2 ppm - B/W (ISO/IEC 24734) , Printing: up to 3.1 ppm - colour (ISO/IEC 24734) , Printing: up to 30 ppm - B/W , Printing: up to 15 ppm - colour , Printing: 54 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows 7 64-bit Edition, Apple Mac OS X 10.6.x or later, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac
12 Watt
Power Consumption Sleep
3 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
39 cm
30 cm
14.5 cm
4.1 kg
Shipping Width
46.4 cm
Shipping Depth
38 cm
Shipping Height
20 cm
8SGR Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.37
8SGR Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.78
8SGR Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.78
8SGR Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.22
