Sharp and accurate image reproduction
Thanks to the Expression 12000XL Pro's top-of-the-range scanning technology, users can achieve extremely high-quality image reproduction up to A3 format. Easy-to-use, Epson Scan operates in either automatic or professional modes, allowing users to optimise their scanning results.
The Expression 12000XL Pro's optical density of 3.8 DMax and 48-bit colour depth ensure sharp and accurate scanning for full reproduction of the widest range of colours, even in shadow areas. In addition, the high 2400 x 4800dpi resolution and ultra-precise Micro Step Drive technology, enable users to capture even the tiniest details with exceptional clarity.
Sharpen and edit your scans
A comprehensive package of bundled software and imaging technology ensures the Expression 12000XL Pro can perform a wide range of functions easily and efficiently. Epson Scan comes with useful features for removing dust noise and grain reduction to smooth the appearance of images. SilverFast Ai 8.8's image-processing functions help get even closer to perfect image reproduction.
Scan a range of media, including film negatives
The included transparency unit enables users to scan from transparency media, such as positive or negative film and slides, with professional results.
A3 film and graphics scanner
High-quality A3 film and graphics scanner for sharp and accurate capturing of plans, x-rays, film negatives, with the precision users demand.
- Epson Expression 12000XL Pro - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Light Source
- LED
- Max Supported Document Size
- DIN A3 (310 x 437 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 16-bit (64k colours)
- Grayscale / Color Depth (External)
- 48-bit colour / 48-bit colour
- Optical Resolution
- 2400 dpi x 4800 dpi
- Max Document Size
- 310 mm x 437 mm
- Document Feeder Type
- Manual
- System Requirements
- Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Apple MacOS X 10.11
- 65.5 cm x 46 cm x 29.2 cm
- 20.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- 48-bit colour
- Colour Depth
- 16-bit (64k colours)
- Colour Depth (External)
- 48-bit colour
- Bulb / Light Source Type
- LED
- Scan Density Range
- 3.8D
- Scanner Speed Details
- 7 sec/scan - greyscale - A4 - 300 dpi , 7 sec/scan - colour - A4 - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology
Media Handling
- Max Document Size
- 310 mm x 437 mm
- Manual
- Interfaces Details
- USB 2.0 - Type B
- Included Accessories
- A3 transparency unit
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- EPSON Scan 2, SilverFast Ai Studio 8.8
- OS Required
- 65.5 cm
- 46 cm
- 29.2 cm
- 20.5 kg
- 5 °C
- 35 °C
- 10 - 80%
