Sharp and accurate image reproduction
Thanks to the Expression 12000XL's top-of-the-range scanning technology, users can achieve extremely high-quality image reproduction up to A3 format. Easy-to-use, Epson Scan operates in either automatic or professional modes, allowing users to optimise their scanning results.
Sharpen and edit your scans
A comprehensive package of bundled software and imaging technology ensures the Expression 12000XL can perform a wide range of functions easily and efficiently. Epson Scan comes with useful features for removing dust noise and grain reduction to smooth the appearance of images. SilverFast Ai 8.8's image-processing functions help get even closer to perfect image reproduction.
The Expression 12000XL is a high-resolution A3 scanner designed to meet the most demanding graphic arts applications. Featuring Epson Scan advanced imaging features, an LED light source, and exceptional SilverFast Ai 8.8 image-processing functions, this scanner offers excellent image reproduction.
The Expression 12000XL's optical density of 3.8 DMax and 48-bit colour depth ensure sharp and accurate scanning for full reproduction of the widest range of colours, even in shadow areas. In addition, the high 2400 x 4800dpi resolution and ultra-precise Micro Step Drive technology, enable users to capture even the tiniest details with exceptional clarity.
Scan a range of media, including film negatives
The optional transparency unit enables users to scan from transparency media, such as positive or negative film and slides, with professional results.
Key Features
- A3 graphics scanner: Professional results up to A3 format
- Superior quality: 2,400 x 4,800dpi resolution
- High precision: Micro Step Drive technology
- Powerful software: Silverfast Ai 8.8
- Optional TPU: Transparency unit for film and slides
Thanks to the Expression 12000XL's top-of-the-range scanning technology, users can achieve extremely high-quality image reproduction up to A3 format. Easy-to-use, Epson Scan operates in either automatic or professional modes, allowing users to optimise their scanning results. -
A comprehensive package of bundled software and imaging technology ensures the Expression 12000XL can perform a wide range of functions easily and efficiently. Epson Scan comes with useful features for removing dust noise and grain reduction to smooth the appearance of images. SilverFast Ai 8.8's image-processing functions help get even closer to perfect image reproduction. -
- Epson Expression 12000XL - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Light Source
- LED
- Max Supported Document Size
- DIN A3 (310 x 437 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 16-bit (64k colours)
- Grayscale / Color Depth (External)
- 48-bit colour / 48-bit colour
- Optical Resolution
- 2400 dpi x 4800 dpi
- Max Document Size
- 310 mm x 437 mm
- Document Feeder Type
- Manual
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Apple MacOS X 10.11.x
- 65.5 cm x 45.8 cm x 15.8 cm
- 14.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- 48-bit colour
- Colour Depth
- 16-bit (64k colours)
- Colour Depth (External)
- 48-bit colour
- Bulb / Light Source Type
- LED
- Scan Density Range
- 3.8D
- Scanner Speed Details
- 12 sec/scan - greyscale - A4 - 300 dpi , 12 sec/scan - colour - A4 - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology
Media Handling
- Max Document Size
- 310 mm x 437 mm
- Manual
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- EPSON Scan 2, SilverFast Ai Studio 8.8
- OS Required
- 65.5 cm
- 45.8 cm
- 15.8 cm
- 14.3 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 10 - 80%
- Sound Emission
- 60 dBA
