Epson Expression 11000XL Flatbed Colour Scanner
Quicklinx: 8VYVWS00 Mfr#: B11B208301BY
Thanks to the Expression 11000XL's top-of-the-range scanning technology, users can achieve extremely high-quality image reproduction up to A3 format. Easy-to-use, Epson Scan operates in either automatic or professional modes, allowing users to optimize their scanning results.
The Expression 11000XL's optical density of 3.8 DMax and 48-bit colour depth ensure sharp and accurate scanning for full reproduction of the widest range of colours, even in shadow areas. In addition, the high 2400 x 4800dpi resolution and ultra-precise Micro Step Drive technology, enable users to capture even the tiniest details with exceptional clarity.
A comprehensive package of bundled software and imaging technology ensures the Expression 11000XL can perform a wide range of functions easily and efficiently. Epson Scan comes with useful features for removing dust noise and grain reduction to smooth the appearance of images. SilverFast Ai8 is also included, with an intuitive user-friendly interface and image-processing functions to help get even closer to perfect image reproduction.
The optional transparency unit enables users to scan from transparency media, such as positive or negative film and slides, with professional results.
  • A3 graphic scanner
    High-resolution A3 scanner gives the sharpness and accuracy required to meet the standards of the graphic arts industry.
Epson Expression 11000XL - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Light Source
Xenon gas fluorescent lamp
Max Supported Document Size
DIN A3 (310 x 437 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Max Document Size
310 mm x 437 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8, Windows 8
65.5 cm x 45.8 cm x 15.8 cm
14.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Bulb / Light Source Type
Scan Density Range
3.8D
Scanner Speed Details
7 sec/scan - greyscale - 200 dpi , 7 sec/scan - colour - 200 dpi , 2.7 ms/line - greyscale , 8 ms/line - colour
Media Handling
Max Document Size
310 mm x 437 mm
Plain paper
Manual
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
Power Consumption Operational (Standby)
45 Watt (0.5 Watt)
Software Included
Drivers & Utilities, EPSON Scan, SilverFast Ai Studio 8
65.5 cm
45.8 cm
15.8 cm
14.5 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
