This cartridge-free model is designed for printing lots of photos at ultra-low cost. For high-quality results, it uses four dyes and a pigment ink. It's hassle-free to use with an SD card slot, borderless photo printing and dual paper trays. It's also easy to set up, reliable and designed for mess-free refills.
Quality A3 photo printing
This 3-in-1 EcoTank provides an ultra-low-cost solution for high-quality photo printing up to A3, with its ultra-high-capacity ink tanks.
- Epson EcoTank ET-7750 - multifunction printer - colour
- Multifunction printer
- Localisation
- United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 5-ink
- Max Printing Speed
- Up to 13 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Printing Resolution Class
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Media Size
- A3 (297 x 420 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, printable CD/DVD disc
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, LAN, USB host, Wi-Fi
- AirPrint Enabled
- Power
- AC 230 V
- 52.6 cm x 41.5 cm x 16.8 cm
- 10.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Ink-jet - colour
- Display Colour Support
- Interface
- AirPrint Enabled
- Localisation
- United Kingdom
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 360 nozzles (black), 180 nozzles (per colour)
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, photo black
- 5-ink
- Minimum Ink Droplet Size
- 1.5 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A3
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets , CD/DVD tray , Bypass tray
- Speed Details
- Printing: up to 28 ppm - B/W , Printing: up to 28 ppm - colour , Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: up to 5.5 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour duplex (ISO/IEC 24734) , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1
- Voltage Required
- AC 230 V
- 15 Watt
- Power Consumption Sleep
- 1 Watt
- Consumables Included
- 2 x ink tank (black) - up to 14000 pages , 2 x ink tank (cyan) - up to 9000 pages , 2 x ink tank (magenta) - up to 9000 pages , 2 x ink tank (yellow) - up to 9000 pages , 2 x ink tank (photo black) , 1 x maintenance cartridge
- ENERGY STAR Certified
- Limited warranty - 3 years
- 52.6 cm
- 41.5 cm
- 16.8 cm
- 10.5 kg
- Sound Emission
- 37 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £16.37 |
Epson Premium Glossy A4 Photo Paper 15 Sheets | In Stock | £12.84 |
Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) | In Stock | £12.84 |
Epson Premium Glossy Photo Paper - 30 Sheets | In Stock | £9.61 |
Epson Premium Glossy Photo Paper - 100 x 150 mm - 40 sheets | In Stock | £9.13 |
Epson A3 Premium Glossy Photo Paper | In Stock | £30.89 |
Epson Ultra Glossy Photo Paper 10x15 50 Sheets | In Stock | £14.03 |
Epson A4 Glossy Photo Paper 20 Sheets | In Stock | £9.92 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £7.26 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.78 |
Epson 106 EcoTank Cyan Ink Bottle | In Stock | £8.47 |
Epson 106 EcoTank Magenta Ink Bottle | In Stock | £9.02 |
Epson 106 EcoTank Yellow Ink Bottle | In Stock | £9.02 |
Epson 105 EcoTank Black Ink Bottle | In Stock | £13.04 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.22 |
