The genuine Epson ELPLP45 ultra high efficiency (UHE) projector lamp is designed as a replacement projector bulb for the Epson PowerLite 6110i Projector.
The ELPLP45 replacement projector lamp is rated at 230W. The lamp is user-replaceable. Lamp module can be installed whether projector mounted on the ceiling or sitting on a tabletop; refer to your projector's manual for installation instructions for this replacement lamp.
