Epson ELPSC26 Projector Screen 80" Multi-Aspect 4:3
Quicklinx: 9XR5WS00 Mfr#: V12H002S26
Accessory Type: Projection screen
£147.33 ex VAT
£176.79 inc VAT
The Epson multi-aspect screen offers you all-in-one screen solution, which fits all projectors. Thanks to its flexible set-up feature, you can easily adjust the screen to 4:3, 16:9 or 16:10 aspect ratios within seconds. Its exceptional value is complemented by its compact size and portable weight, offering you extra flexibility. The Epson multi-aspect screen is definitely your preferred partner for business or home projection.
  • No more big black boxes
    There's no need to let a big, black TV screen permanently dominate your space. By using a non-fixed screen and projector, you'll have the flexibility to view content on a big screen when you need it and hide it away when it's not in use.
  • Make the most of your projector
    Don't settle for projecting on to a bare wall – with our screens you can enjoy the exceptional detail, vibrant colours, defined shadows and deep blacks that your projector provides.
  • Fuss-free assembly
    Forget complicated instructions and lengthy installations, our screens are quick and easy to assemble. Just like our projectors, Epson screens are designed to get you up and running with minimal fuss. What's more, they're also easy to stow away.
  • Flexible positioning
    Our versatile screens can be used in almost any room and can be easily adjusted so that you can get the best out of your projector.
Epson 65"/74"/80" Multi-aspect - projection screen - 80" (203.2 cm)
Projection screen
Projection Screen Image Diagonal Size
80" (203.2 cm)
Aspect Ratio
16:10 / 16:9 / 4:3
10 kg
Epson EB-1750, 1751, 1760, 1761, 1770, 1771, 1775, 1776, 1840, 1860, 1900, 1920, 1925, 945, 955, 965, 98, S02, S03, S04, S10, S17, S18, S27, S31, S92, U04, U32, W03, W04, W06, W110, W18, W28, W29, W31, W32, X03, X10, X11, X15, X18, X24, X27, X31, x92, EH-TW550, TW5705, TW5825
Projection screen
Image Diagonal Size
80" (203.2 cm)
Aspect Ratio
16:10 / 16:9 / 4:3
10 kg
Epson EB-1750, EB-1751, EB-1760W, EB-1761W, EB-1770W, EB-1771W, EB-1775W, EB-1776W, EB-1840W, EB-1860, EB-1900, EB-1920W, EB-1925W, EB-945H, EB-955WH, EB-965H, EB-98H, EB-S02, EB-S02H, EB-S03, EB-S04, EB-S10, EB-S17, EB-S18, EB-S27, EB-S31, EB-S92, EB-U04, EB-U32, EB-W03, EB-W04, EB-W06, EB-W110, EB-W18, EB-W28, EB-W29, EB-W31, EB-W32, EB-X03, EB-X10, EB-X11, EB-X15, EB-X18, EB-X24, EB-X27, EB-X31, EB-x92, EH-TW550, EH-TW5705, EH-TW5825
Brand: Epson
