Epson ELP-DC20 Visualiser
5 YEAR WARRANTY!!!
Quicklinx: 8N5MWS00 Mfr#: V12H500052
The visualiser is packed full of features to enhance classroom teaching. A3-size materials, such as maps and large diagrams, can be easily projected, and the LED light helps illuminate difficult-to-see objects. A split-screen display allows two different sources to be connected at the same time, and real-time microscopic worlds can be observed using the microscope attachment.
A sturdy viewing arm ensures the visualiser stays in a fixed position during presentations. It can be rotated in three different directions for greater flexibility of use, then easily folded away for storage. Added security bar/locks provide schools with peace of mind when the visualiser is not in use.
With PC-free functions, such as real-time annotation, a USB mouse can be connected directly to the visualiser for drawing on live images and illustrating teaching points. The PC-free record-and-replay feature means video footage can be filmed and stored straight onto the 1GB internal memory, then played back in future lessons.
Teachers can liven-up classes with the advanced software included. Time-lapse video, for example, can be used to record video footage for up to 72 hours, allowing gradual events, such as plant growth, to be filmed for use in science lessons. With the built-in microphone, teachers can also add audio commentary to video files, and tag and upload videos to video-sharing websites.
  • Visualiser
    HD resolution visualiser with close-up projection and advanced functions for an enhanced user experience.
Epson ELPDC20 - digital document camera
Digital document camera
Audio
Yes: built-in microphone
3 kg
Wired
Camera
Colour - NTSC, PAL
Optical Zoom
12 x
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/2.7" - 2 MP
Focus Adjustment
Automatic
Lens Iris
F/3.4-5
USB, composite video, VGA, HDMI
Remote control, digital image rotation, digital image freeze, auto exposure control, built-in LED lights, automatic display brightness adjustment, image split, auto white balance
Environmental Parameters (operating)
5 °C - 35 °C; 20 - 80% relative humidity
Audio Support
Wired
3 kg
Camera
Video Format
NTSC, PAL
Digital Video Format
AVI, WMV, MOV, MPG
Digital Zoom
10
Frame Rate (max)
Supported Image Formats
BMP
Still Image Capture Resolution
1024 x 768, 1280 x 1024, 1920 x 1080, 1280 x 800, 1360 x 768
Flash Memory
1 GB
Image Sensor
2 MP CMOS 1/2.7"
Lens Construction
Optical Zoom
12 x
Lens Iris
F/3.4-5
Focus Adjustment
Automatic
Video
Composite video, VGA, HDMI
Computer Interface
USB
1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x display / video - composite video output , 1 x USB - 4 pin USB Type B , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x microphone - input
Supported Memory Cards
SD Memory Card
Remote control
Power adapter AC 230V
AA type
Software Included
Drivers & Utilities
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x, Windows 8
5 °C
35 °C
Relative Humidity (operating)
20 - 80%
