Enjoy Full HD images over WiHD
Irksome cables can be a thing of the past with this WirelessHD projector. It's easy to stream content to your projector from your smartphone, tablet, games console, Blu-ray player and more - without the need for wires.
Sharp, smooth images
Using Epson's 3LCD technology for high brightness and vivid colour, this Full HD projector features high White and Colour Light Output of 3,000 lumens and 70,000:1 dynamic contrast ratio. Together this technology ensures bright, vivid colours and deep blacks. Frame interpolation and Detail Enhancement provide sharper and smoother motion pictures and great detail, for greater clarity, and the EH-TW6700W can also convert standard 2D video into 3D.
Enjoy the big-screen experience with easy set-up
Sit back and immerse yourself in the experience from the very start with our easy to install, simple to use projector that can placed almost anywhere. With this model boasting a 1.6x optical zoom, vertical ±60% and horizontal ±24% keystone correction, superbly aligned images can be achieved effortlessly. Maintenance is also kept to a minimum with the EH-TW6700W. Thanks to the incredibly long lamp life, you can watch a movie every day on the big screen for the next seven years .
Smart control
It's easy to control and change the settings of the EH-TW6700W from any smart device with Epson's iProjection remote app.
WiHD Home cinema projector
Transform your home entertainment experience with our wireless Full HD 2D & 3D projector with 3LCD technology for exceptional images.
- Epson EH-TW6700W - 3LCD projector - 3D - white
- 3LCD projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- White
- Built-in Devices
- Stereo speakers
- Brightness (White)
- 3000 lumens
- Brightness (Colour)
- 3000 lumens
- Contrast Ratio
- 70000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 250 Watt
- Bulb life cycle
- Up to 3500 hours - normal mode , Up to 5000 hours - economic mode
- Video Input
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 364 Watt
- 41 cm x 30.4 cm x 15.7 cm
- 7 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
- Stereo speakers
- Enclosure Colour
- White
Projector
- 3000 lumens
- 3000 lumens
- Contrast Ratio
- 70000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 2.95 m - 4.8 m
- Throw Ratio
- 1.32 - 2.15:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Bulb type
- 250 Watt
- Bulb life cycle
- EPSON 3LCD technology, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 60% / 60%
- Horizontal Lens Shift
- 24% / 24%
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI, MHL
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 20 Watt
- Speakers
- 2 x right / left channel
- HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-out
- Included Accessories
- WirelessHD Transmitter Set, wireless remote control
- Security Features
- Power Source
- AC
- Voltage Required
- 364 Watt
- Power Consumption Stand by
- 0.4 Watt
- 41 cm
- 30.4 cm
- 15.7 cm
- 7 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 32 dBA
- Sound Emission (Economic Mode)
- 24 dBA
