Epson EcoTank ET-4750 Colour Inkjet 33ppm Multifunction Printer
Quicklinx: DKGFWS00 Mfr#: C11CG19401CE
Cartridge-free printing
This next generation EcoTank is a fast 4-in-1 with a 250-sheet paper tray. It can reduce printing costs by 90% on average (1).
Cut your printing costs with Epson’s cartridge-free EcoTank. This 4-in-1 inkjet can reduce printing costs by 90% on average (1). Delivering a ultra-low-cost per page, it can print 14,000 pages in black and 11,200 in colour (2). It has a range of features including Wi-Fi, double-sided printing, a 250 sheet front tray, 30 page ADF, fax and fast 15ppm (4) print speeds.
Key Features
  • Ultra-low-cost per page: Reduce ink costs by 90% (1)
  • Thousands of pages' worth of ink1: Print up to 14,000 pages in black and 11,200 pages in colour (2)
  • Next generation ink filling system: Enjoy hassle and mess-free refills with the enhanced ink bottles
  • Mobile printing and connectivity: Wi-Fi, Wi-Fi Direct, Ethernet & free mobile printing apps (4)
  • Designed for business: 250 sheet front tray, fax, 30 page ADF and double-sided printing
(1). Average number of cartridges/savings for printing the number of pages using the bundled ink bottles with the EcoTank range, excluding hardware price. Comparison made on the average of the A4 EcoTank range versus the average of the top 10 best-selling models in Western Europe, in the period January 2017– December 2017, as tracked by GfK. Printing costs calculated on the proportion of Standard and XL cartridges as tracked by GfK for the same reference period for the Western European market, using average retail prices. Ink cartridge yields as communicated by the manufacturer’s websites. (2). Quoted yields are extrapolated based on Epson original methodology from the print simulation of Test Patterns provided in ISO/IEC 24712. Quoted yields are NOT based on ISO/IEC24711. Quoted yields may vary depending on the images that you are printing, the paper type that you are using, the frequency of your prints and environmental conditions such as temperature. During the initial printer setup, a certain amount of ink is used to fill the print head's nozzles, therefore the yield of the initial bundled set can be lower. (3). Determined in accordance with ISO/IEC 24734 showing the average of ESAT from the Office Category Test for default simplex. For more information visit www.epson.eu/testing (4). Requires a wireless connection to the internet. For more information, supported languages and devices please visit www.epsonconnect.eu
  • Ultra-low cost
    EcoTank can slash printing costs by 90 % on average thanks to its advanced design. It features an ultra-high-capacity ink tank that completely removes the need for cartridges.
  • Print thousands of pages
    Get more prints between refills. Thanks to the ink included in the box, it can print 14000 pages in black and 11200 in color.
  • Discover the next generation of EcoTank
    With the ink tank now housed at the front, EcoTank is more compact and easier to use than ever before. Protecting you against leaks and spills, it features an enhanced ink filling system engineered for mess-free refills.
  • Business quality features
    Produce crisp and clear texts thanks to the PrecisonCore print head and Epson's genuine dye and pigment inks. Designed for business, it offers fax, a 250-sheet tray, double-sided printing, fast print speeds of 15 ppm and a 30 page automatic document feeder (ADF).
  • Print from almost anywhere
    With Wi-Fi and Wi-Fi Direct, send documents to print from smart devices using the Epson iPrint app. It can even receive files from almost anywhere in the world via Epson Email Print.
Epson EcoTank ET-4750 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Max Printing Speed
Up to 15 ppm (mono) / up to 8 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
250 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, LAN, Wi-Fi
AirPrint Enabled
AC 230 V (50/60Hz)
37.5 cm x 34.7 cm x 23.1 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Colour Support
Display Features
Touch screen
USB, LAN, Wi-Fi
AirPrint Enabled
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 128 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.3 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Delayed Transmission
Automatic redialing
Document & Media Handling
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
250 sheets
Input tray - 250 sheets , ADF - 30 sheets
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 15 ppm - B/W (ISO/IEC 24734) , Printing: up to 8 ppm - colour (ISO/IEC 24734) , Printing: up to 6.5 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour duplex (ISO/IEC 24734)
1 x USB , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1
AC 230 V (50/60Hz)
13 Watt
Power Consumption Sleep
1.5 Watt
Consumables Included
2 x ink tank (black) - up to 14000 pages , 2 x ink tank (cyan) - up to 11200 pages , 2 x ink tank (magenta) - up to 11200 pages , 2 x ink tank (yellow) - up to 11200 pages
ENERGY STAR Certified
Limited warranty - 1 year / 50000 pages - carry-in
37.5 cm
34.7 cm
23.1 cm
4.7 kg
Sound Emission
37 dBA (operating)
DKGF Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.39
DKGF Epson Premium Glossy A4 Photo Paper 15 Sheets In Stock £12.87
DKGF Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) In Stock £12.87
DKGF Epson Premium Glossy Photo Paper - 30 Sheets In Stock £9.69
DKGF Epson Premium Glossy Photo Paper - 100 x 150 mm - 40 sheets In Stock £9.14
DKGF Epson Premium Glossy Photo Paper BOGOF - 100 x 150 mm - 255 g/m2 - 40 sheets (pack of 2 ) In Stock £9.14
DKGF Epson Ultra Glossy Photo Paper 10x15 50 Sheets In Stock £14.04
DKGF Epson A4 Glossy Photo Paper 20 Sheets In Stock £9.93
DKGF Epson Glossy Photo Paper 50 Sheets In Stock £8.40
DKGF Epson Glossy Photo Paper 50 Sheets In Stock £7.26
DKGF Epson Glossy Photo Paper 100 Sheets In Stock £9.66
DKGF Epson Glossy Photo Paper 200 Sheets In Stock £34.77
DKGF Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.79
DKGF Epson 102 EcoTank Magenta Ink Bottle In Stock £6.59
DKGF Epson 102 EcoTank Yellow Ink Bottle In Stock £6.57
DKGF Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.79
DKGF Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.23
