Say goodbye to ink cartridges
The star of the ET-4500 is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. That means less fuss and much more printing between refills than other inkjet printers.
Two years of ink
Imagine not having to think about ink for two years. As well as doing away with ink cartridges, the ET-4500 has four colour 70ml Epson genuine ink bottles in the box, which make it easy, clean and quick to fill the ink tanks.
Ultra-low cost
The ET-4500 saves you 70% in printing costs on average. It achieves an ultra-low cost per page, printing up to 4,000 pages in black and 6,500 pages in colour at just a fraction of a penny per page4.
Wi-Fi and Ethernet connectivity
Equipped with Wi-Fi and Wi-Fi direct, the ET-4500 can take advantage of all Epson Connect5 features. Print quickly and easily over Wi-Fi from a smartphone using the free Epson iPrint app, print remotely or email the ET-4500 a print job.
Quick, quality results
The ET-4500 uses Epson's own Micro Piezo technology for excellent-quality print-outs. Mono prints are delivered at a rate of 9.2 pages per minute while it can issue 4.5 colour pages per minute. A 30-page ADF helps boost productivity.
Cartridge-free printing
Great for any home office, this 4-in-1 inkjet printer can reduce ink costs by 90% on average .
- Epson EcoTank ET-4500 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 9.2 ppm (mono) / up to 4.5 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Connection Availability
- Interface
- USB, LAN, Wi-Fi
- AirPrint Enabled
- Power
- AC 120/230 V
- 49 cm x 37.7 cm x 22.9 cm
- 6.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Interface
- USB, LAN, Wi-Fi
- AirPrint Enabled
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 60 station(s)
- Automatic redialing, colour faxing, delayed sending
Document & Media Handling
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 100 sheets
- Input tray - 100 sheets , ADF - 30 sheets
- Speed Details
- Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: up to 9.2 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour (ISO/IEC 24734)
- 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
- WEP, WPA-PSK
- Operating System Support
- MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
- Software Included
- Epson Event Manager, EPSON Scan, Epson Fax Utility, EpsonNet Config
- Voltage Required
- AC 120/230 V
- 11 Watt
- Power Consumption Sleep
- 1.6 Watt
- Consumables Included
- 1 x ink tank (black) - up to 4000 pages , 1 x ink tank (cyan) - up to 6500 pages , 1 x ink tank (magenta) - up to 6500 pages , 1 x ink tank (yellow) - up to 6500 pages
- ENERGY STAR Certified
- 49 cm
- 37.7 cm
- 22.9 cm
- 6.3 kg
- Sound Emission
- 39 dBA (operating)
Epson T6641 Black Ink bottle for L Series | In Stock | £6.63 |
Epson T6642 Cyan Ink Bottle L-Series Ink Tank | In Stock | £6.89 |
Epson T6643 Magenta Ink Bottle L-Series Ink Tank | In Stock | £6.63 |
Epson T6644 Yellow Ink Bottle L-Series Ink Tank | In Stock | £6.68 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £12.18 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.32 |
