Shrink your overheads with Epson's cartridge-free EcoTank, which can reduce printing costs. This 3-in-1 inkjet with Wi-Fi and Wi-Fi Direct features fast print speeds and double-sided printing.
Ultra-low cost
EcoTank can slash ink costs by 90% on average thanks to its innovative design. It features an ultra-high-capacity ink tank that removes the need for cartridges. This model comes with an additional set of ink bottles. -
Print thousands of pages
Get more prints between refills. Thanks to the ink included in the box, it can print 14,000 pages in black and 11,200 in colour. -
Discover the next generation of EcoTank
With the ink tank now housed at the front, EcoTank is more compact and easier to use than ever before. Protecting you against leaks and spills, it features an enhanced ink filling system engineered for mess-free refills. The new bottles also incorporate a mechanism to ensure that only the correct colours are inserted. -
Print from almost anywhere
With Wi-Fi and Wi-Fi Direct, you can send documents to print from smart devices using the Epson iPrint app. It can even receive files from almost anywhere in the world via Epson Email Print.
- Epson EcoTank ET-3750 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Max Printing Speed
- Up to 15 ppm (mono) / up to 8 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Printing Resolution Class
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 30 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, LAN, Wi-Fi
- AirPrint Enabled
- Power
- AC 230 V (50/60Hz)
- 37.5 cm x 34.7 cm x 23.1 cm
- 4.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- Display Colour Support
- Interface
- USB, LAN, Wi-Fi
- AirPrint Enabled
Printing
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 128 nozzles (per colour)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.3 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 150 sheets
- 30 sheets
- Input tray - 150 sheets , ADF - 30 sheets , Output tray - 30 sheets
- Speed Details
- Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 15 ppm - B/W (ISO/IEC 24734) , Printing: up to 8 ppm - colour (ISO/IEC 24734) , Printing: up to 6.5 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour duplex (ISO/IEC 24734)
- 1 x USB , 1 x LAN - RJ-45
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1
- Voltage Required
- 13 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 2 x ink tank (black) - up to 14000 pages , 2 x ink tank (cyan) - up to 11200 pages , 2 x ink tank (magenta) - up to 11200 pages , 2 x ink tank (yellow) - up to 11200 pages
- ENERGY STAR Certified
- Limited warranty - 1 year / 50000 pages - carry-in
- 37.5 cm
- 34.7 cm
- 23.1 cm
- 4.7 kg
- Sound Emission
- 38 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Premium Glossy A4 Photo Paper 15 Sheets | In Stock | £12.40 |
Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) | In Stock | £12.40 |
Epson Premium Glossy Photo Paper - 30 Sheets | In Stock | £9.58 |
Epson Premium Glossy Photo Paper - 100 x 150 mm - 40 sheets | In Stock | £7.92 |
Epson Ultra Glossy Photo Paper 10x15 50 Sheets | In Stock | £12.70 |
Epson A4 Glossy Photo Paper 20 Sheets | In Stock | £9.58 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £8.10 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £6.99 |
Epson Glossy Photo Paper 100 Sheets | In Stock | £8.67 |
Epson Glossy Photo Paper 200 Sheets | In Stock | £29.72 |
Epson A4 Glossy Photo Paper 50 Sheets | In Stock | £18.74 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson 102 EcoTank Magenta Ink Bottle | In Stock | £7.10 |
Epson 102 EcoTank Yellow Ink Bottle | In Stock | £7.10 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
