When life is demanding, you need an ultra-low-cost printer that can take care of itself. With Epson's cartridge-free EcoTank, you receive minimal refills and no extra ink costs. An ideal solution for busy households, this reliable and easy-to-use model features an enhanced ink filling system and ink bottles engineered for mess-free refills.
Cartridge-free printing
Go longer between refills with EcoTank. It uses ultra-high-capacity ink tanks to completely remove the need for cartridges. -
Discover the next generation of EcoTank
With the ink tank now housed at the front, EcoTank is more compact and easier to use than ever before. Protecting you against leaks and spills, it features an enhanced ink filling system engineered for mess-free refills. The bottles also incorporate a mechanism to ensure that only the correct colors are inserted. Thanks to the front ink level display, it's now easy to see when it's finally due for a refill.
- Epson EcoTank ET-2700 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 10.5 ppm (mono) / up to 5 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Printing Resolution Class
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Output Trays Capacity
- 30 sheets
- Connection Availability
- Interface
- USB, Wi-Fi
- AirPrint Enabled
- Power
- AC 230 V (50/60Hz)
- 37.5 cm x 34.7 cm x 18.7 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- Interface
- USB, Wi-Fi
- AirPrint Enabled
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- 30 sheets
- Input tray - 100 sheets , Output tray - 30 sheets
- Speed Details
- Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: up to 10.5 ppm - B/W (ISO/IEC 24734) , Printing: up to 5 ppm - colour (ISO/IEC 24734)
- 1 x USB
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1
- Voltage Required
- 13 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 1 x ink tank (black) - up to 6500 pages , 1 x ink tank (cyan) - up to 5200 pages , 1 x ink tank (magenta) - up to 5200 pages , 1 x ink tank (yellow) - up to 5200 pages
- ENERGY STAR Certified
- Limited warranty - 1 year / 30000 pages
- 37.5 cm
- 34.7 cm
- 18.7 cm
- 5.5 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £16.39 |
Epson Premium Glossy A4 Photo Paper 15 Sheets | In Stock | £12.87 |
Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) | In Stock | £12.87 |
Epson Premium Glossy Photo Paper - 30 Sheets | In Stock | £9.69 |
Epson Premium Glossy Photo Paper - 100 x 150 mm - 40 sheets | In Stock | £9.14 |
Epson Premium Glossy Photo Paper BOGOF - 100 x 150 mm - 255 g/m2 - 40 sheets (pack of 2 ) | In Stock | £9.14 |
Epson Ultra Glossy Photo Paper 10x15 50 Sheets | In Stock | £14.04 |
Epson A4 Glossy Photo Paper 20 Sheets | In Stock | £9.93 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £8.40 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £7.26 |
Epson Glossy Photo Paper 100 Sheets | In Stock | £9.66 |
Epson Glossy Photo Paper 200 Sheets | In Stock | £34.77 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.79 |
Epson 102 EcoTank Magenta Ink Bottle | In Stock | £6.59 |
Epson 102 EcoTank Yellow Ink Bottle | In Stock | £6.57 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.79 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.23 |
