The wide-format WorkForce ET-16500 EcoTank wireless all-in-one offers revolutionary cartridge-free printing with easy-to-fill supersized ink tanks. Powered by PrecisionCore printing technology, this all-in-one delivers laser-quality text and prints. The ET-16500 features a big paper capacity and rear specialty-paper feed, plus a color touchscreen for easy navigation.
- Epson EcoTank ET-16500 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Max Printing Speed
- Up to 18 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A3 Plus (329 x 483 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 500 sheets
- Output Trays Capacity
- 125 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB, LAN, USB host, Wi-Fi
- Power
- AC 120/230 V (50/60Hz)
- 66.6 cm x 48.6 cm x 41.8 cm
- 23.16 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Colour Support
- Display Features
- Touch screen
- Interface
- Supported Flash Memory
- SD Memory Card, Memory Stick Duo, SDXC Memory Card
Copying
Printing
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 128 nozzles (per colour)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 2.8 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 550 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Delayed Transmission
- Automatic redialing
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A3
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 90 x 130 mm, A3 Plus (329 x 483 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 500 sheets
- 125 sheets
- 2 x input tray - 250 sheets , ADF - 35 sheets , Output tray - 125 sheets
- Speed Details
- Printing: up to 32 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 18 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: up to 8.7 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 6 ppm (A4) - colour duplex (ISO/IEC 24734)
- 1 x USB , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows XP 64-bit Edition, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2012 x64 Edition, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Windows 10
- Software Included
- Epson Event Manager, EPSON Scan, Epson Easy Photo Print, EpsonNet Print, EpsonNet Setup
- Voltage Required
- 20 Watt
- Power Consumption Standby
- 9.1 Watt
- Power Consumption Sleep
- 2 Watt
- Consumables Included
- 2 x ink tank (black) - up to 10500 pages , 2 x ink tank (cyan) - up to 11300 pages , 2 x ink tank (magenta) - up to 11300 pages , 2 x ink tank (yellow) - up to 11300 pages
- ENERGY STAR Certified
- Limited warranty - 1 year / 80000 pages - carry-in
- 66.6 cm
- 48.6 cm
- 41.8 cm
- 23.16 kg
- Sound Emission
- 44 dBA (operating)
Epson T6642 Cyan Ink Bottle L-Series Ink Tank | In Stock | £6.74 |
Epson T6643 Magenta Ink Bottle L-Series Ink Tank | In Stock | £6.63 |
Epson T6644 Yellow Ink Bottle L-Series Ink Tank | In Stock | £6.68 |
Epson T7741 Pigment Black Ink Bottle | In Stock | £9.92 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.89 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £28.48 |
