Say goodbye to ink cartridges
The star of the ET-14000 is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. In fact, the ET-14000 features two black ink tanks, meaning that there's even less fuss and much more printing between refills than other inkjet printers. As well as doing away with ink cartridges, the ET-14000 includes two black ink bottles in the box, in addition to its set of 70ml Epson genuine colour ink bottles. The ink bottles make it easy, clean and quick to fill the ink tanks .
Ultra-low cost printing up to A3+
The included ink bottles can print up to 7,100 pages in black and 5,700 pages in colour , delivering the lowest A3 cost-per-page on the market .
Quick, quality results
The ET-14000 uses Epson's own Micro Piezo technology for excellent-quality print-outs. In addition, the use of two black ink tanks helps boost print speeds. Mono print-outs are delivered at a rate of 15 pages per minute while it can issue 5.5 colour pages per minute .
- Epson EcoTank ET-14000 - printer - colour - ink-jet
- Printer Type
- Personal printer - ink-jet - colour
- 12.2 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A3
- Max Media Size
- Legal (216 x 356 mm), A3 Plus (329 x 483 mm)
- Print Speed
- Up to 30 ppm - B/W , Up to 17 ppm - colour , Up to 15 ppm - B/W (ISO/IEC 24734) , Up to 5.5 ppm - colour (ISO/IEC 24734)
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Interface
- USB
- Media Type
- Envelopes, plain paper, photo paper
- Total Media Capacity
- 100 sheets
- Media Handling
- 100-sheet input tray
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.5.8 or later, Windows 8, Windows 8.1
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 70.5 cm x 32.2 cm x 21.5 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 360 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
- Minimum Ink Droplet Size
- 3 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 5760 x 1440 dpi
- 5760 x 1440 dpi
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 130 x 200 mm, A3 Plus (329 x 483 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Media Feeders
- 1 x automatic - 100 rolls - A3 Plus (329 x 483 mm)
- Output Trays Capacity
- 40 sheets
- Connections
- 1 x USB
- Consumables Included
- 2 x ink cartridge (black) - 70 ml - up to 7100 pages ISO/IEC 24711 , 1 x ink cartridge (cyan) - 70 ml - up to 5700 pages ISO/IEC 24711 , 1 x ink cartridge (magenta) - 70 ml - up to 5700 pages ISO/IEC 24711 , 1 x ink cartridge (yellow) - 70 ml - up to 5700 pages ISO/IEC 24711
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50 - 60 Hz
- 20 Watt
- Power Consumption Sleep
- 1.6 Watt
- OS Required
- 1-year warranty
- Sound Emission (Operating)
- 38 dBA
- 70.5 cm
- 32.2 cm
- 21.5 cm
- 12.2 kg
Epson Premium Glossy A4 Photo Paper 15 Sheets | In Stock | £11.17 |
Epson Premium Glossy Photo Paper - 30 Sheets | In Stock | £8.33 |
Epson Premium Glossy Photo Paper - 100 x 150 mm - 40 sheets | In Stock | £7.69 |
Epson Premium Glossy Photo Paper BOGOF - 100 x 150 mm - 255 g/m2 - 40 sheets (pack of 2 ) | In Stock | £8.40 |
Epson A3 Premium Glossy Photo Paper | In Stock | £29.09 |
Epson T6641 Black Ink bottle for L Series | In Stock | £6.40 |
Epson T6642 Cyan Ink Bottle L-Series Ink Tank | In Stock | £6.40 |
Epson T6643 Magenta Ink Bottle L-Series Ink Tank | In Stock | £6.40 |
Epson T6644 Yellow Ink Bottle L-Series Ink Tank | In Stock | £6.39 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £10.57 |
Epson A3+ Glossy Photo Paper | In Stock | £19.29 |
