Epson EBW16 WXGA LCD 3000 Lumens Meeting Room Projector
Quicklinx: 8PS6WS00 Mfr#: V11H493041
The Epson EB-W16 delivers visibly brighter colour content than an equivalent single chip DLP projector, thanks to Epson's 3LCD technology. Combined with superb colour reproduction, the Epson EB-W16 delivers bright, easy-on-the-eye, high-quality 3D images, while a 5,000:1 contrast ratio provides superb detail for outstanding quality.
With a pair of lightweight, rechargeable Radio Frequency (RF) active shutter 3D glasses , users can view their content without interference. These industry-standard glasses mean users can keep them for future upgrades, as well as using them with compatible 3D projector and flat panel displays from other manufacturers.
Supporting all HDMI compatible 3D signal formats, the Epson EB-W16 displays side-by- side, top-and-bottom, and frame packed content, providing users with the ability to project the widest range of 3D content available.
Quick to set up, the Epson EB-W16 offers automatic horizontal and vertical keystone correction as well as a screen fit function which automatically resizes the projected image to perfectly fit a framed projection screen. In addition, the slim, lightweight, portable design of the EB-W16, combined with x1.2 zoom, enables users to display 3D content almost anywhere.
  • Enhanced connectivity
    With a variety of interface options including HDMI, VGA, and USB, the Epson EB-W16 projector offers versatile connectivity, ensuring compatibility with a wide range of devices for seamless presentation and multimedia experiences.
  • High-quality image
    Boasting a brightness of 3000 lumens and a high contrast ratio of 5000:1, the EB-W16 delivers vivid, bright images and sharp, clear text, making it suitable for any presentation or multimedia need.
  • Flexible installation
    Featuring manual zoom, horizontal and vertical keystone correction, the Epson EB-W16 allows for quick and easy setup in various environments, ensuring a perfectly proportioned image every time.
  • Durable performance
    With a lamp life of up to 5000 hours in economic mode, the EB-W16 offers extended usability and reduced maintenance costs, making it a cost-effective solution for your projection needs.
  • 3D capability
    The Epson EB-W16 comes with 3D support, providing an immersive viewing experience for presentations, videos, and educational content, making every viewing experience memorable.
Epson EB-W16 - 3LCD projector - portable - 3D
3LCD projector
3D Capable
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
5000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video
Speakers
Speaker(s) - integrated
AC 230V (50/60 Hz)
311 Watt
34.5 cm x 26.3 cm x 9.3 cm
2.6 kg
3-year warranty
3LCD projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
5000:1
Image Size
90 cm - 900 cm
Projection Distance
1.1 m - 10.8 m
Throw Ratio
1.3 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Display Format
1,024,000 pixels (1,280 x 800) x 3
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Auto Vertical Keystone, EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
2 Watt
1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 , 1 x network - RJ-45 , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input , 1 x S-video input , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm
Carrying case, wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection
AC 230V (50/60 Hz)
311 Watt
Power Consumption Operational (Standby)
0.47 Watt
34.5 cm
26.3 cm
9.3 cm
2.6 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
Sound Emission
36 dBA
29 dBA
