Epson EB824 XGA Projector - 3 year unlimited lamp warranty
WAS £599 - WHILST STOCKS LAST
Quicklinx: 6B92WS00 Mfr#: V11H325B40
Epson is pleased to introduce the Epson EB-824 3LCD multimedia projector. Powerful and easy to use, this projector offers low cost of ownership, and ease of maintenance. Beautiful crisp, clear images make the EB-824 the ideal choice for use in a wide variety of corporate and education environments.
With a category leading lamp life expectancy, low power consumption, and powerful 3,000 lumens brightness, the EB-824 is ideally suited for use in the modern classroom or office environment.
  • Powerful 3,000 lumens brightness
    The Epson EB-824 is capable of producing a high-brightness Light Output of 3,000 lumens and a Color Light Output of 3,000 lumens making it ideal for classroom use. With this powerful projector you don't have to dim the lights or close the windows in order to see a bright, clear image.
  • Long lamp life and easy maintenance
    Lamp life for the EB-824 is an impressive 5,000 hours in high brightness mode or an amazing 6,000 hours in low brightness mode. By the time you need to change the lamp in the EB-824, you may have changed up to 2.5 lamps if you had used a competitor's product from this category. Maintaining the EB-824 is easy even when ceiling mounted. Changing the filter or lamp is a simple in-situ, end-user changeable operation meaning you don't require the additional expense of a visit from a service agent.
  • USB display function and USB memory slide show
    The EB-824 can display your presentation via a connection to a PC with a simple USB cable. You can also create and display images directly from a USB memory device, making it possible to give presentations without the need for a PC.
  • Direct connect to ELP-DC06
    Further enhancing suitability to the modern classroom is the ability for the EB-824 to connect directly to the Epson ELP-DC06 document camera/visualize. These Epson products feature unique technology enabling them to connect via USB and provide full operation without the need for a PC.
Epson EB-824 - 3LCD projector - LAN
3LCD projector
Built-in Devices
Speaker
Ethernet
Brightness
3000 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video LAN
Video Output
RGB
Speakers
Speaker(s) - internal
275 Watt
32.7 cm x 25 cm x 9.5 cm
3.1 kg
3-year warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Ethernet
Projector
Brightness
3000 lumens
Brightness (Reduced)
2600 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
0.83 m - 8.54 m
Throw Ratio
1.38 - 2.24:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
EPSON 3LCD technology, Wireless Ready
Lens
Focus Type
Manual
Lens Aperture
F/1.49-1.94
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Video Output
Analogue Video Signal
RGB
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 2 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
Carrying case, wireless remote control
1 x VGA cable - 1.8 m , 1 x USB cable - 1.8 m
Security Features
Password protection, control panel lock
275 Watt
Power Consumption Operational (Standby)
3 Watt
32.7 cm
25 cm
9.5 cm
3.1 kg
Limited warranty - 3 years - on-site , Limited warranty - lamp - 3 years
5 °C
35 °C
