Clear images and 3LCD technology
At 10,000 lumens the EB-Z10005U is Epson's brightest WUXGA resolution projector yet. This projector benefits from Epson's 3LCD technology, which ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors .
Perfect for large venues
Museums, auditoriums and corporate environments can benefit from the EB-Z10005U's large projected image, ideal for making a big impact.
Portrait projection
Able to project portrait aspect images, the EB-Z10005U is ideal for digital signage. Welcome to a whole new way of seeing things; portrait mode is also useful when a venue or event, such a fashion show, doesn't lend itself to landscape projection.
Easy set-up
As well as a flexible installation angle and lens shift for off-centre positioning, the EB-Z10005U includes plenty of calibration options such as edge blending, test patterns, frame interpolation and Epson's Super Resolution feature.
The EB-Z10005U includes HDBaseT, which allows up to five connections in one. Optional Wi-Fi and SDI are also included for extra flexibility.
Short-throw capability
Great news for auditoriums and lecture theatres; a new and exclusive LU02 short throw lens allows this projector to be positioned closer to the screen.
At 10,000 lumens the EB-Z10005U is Epson's brightest WUXGA resolution projector yet. This projector benefits from Epson's 3LCD technology, which ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors. -
Museums, auditoriums and corporate environments can benefit from the EB-Z10005U's large projected image, ideal for making a big impact. -
Portrait projection
Able to project portrait aspect images, the EB-Z10005U is ideal for digital signage. Welcome to a whole new way of seeing things; portrait mode is also useful when a venue or event, such a fashion show, doesn't lend itself to landscape projection. -
Easy set-up
As well as a flexible installation angle and lens shift for off-centre positioning, the EB-Z10005U includes plenty of calibration options such as edge blending, test patterns, frame interpolation and Epson's Super Resolution feature. -
The EB-Z10005U includes HDBaseT, which allows up to five connections in one. Optional Wi-Fi and SDI are also included for extra flexibility. -
- Epson EB-Z10005U - 3LCD projector
- 3LCD projector - 1080p
- Brightness (White)
- 10000 lumens
- Brightness (Colour)
- 10000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 380 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video
- Power
- AC 120/230 V (50/60 Hz)
- 1060 Watt
- 74.1 cm x 53.4 cm x 19.7 cm
- 26 kg
- 3-year warranty
Projector
- 10000 lumens
- 10000 lumens
- Brightness (Reduced)
- 6600 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 152.4 cm - 1270 cm
- Projection Distance
- 2 m - 27.8 m
- Throw Ratio
- 1.57 - 2.56:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Bulb type
- 380 Watt
- Bulb life cycle
- EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), 16:10 aspect ratio support, DICOM Simulation Mode, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Powered
- Lens Aperture
- F/1.65-2.51
- Zoom Type
- Powered
- Zoom Factor
- 1.61x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Powered
- Vertical Lens Shift
- 60% / 60%
- Horizontal Lens Shift
- 18% / 18%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video, DVI, HD-SDI
- 1 x USB - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input , 1 x composite video input , 1 x component video input , 1 x composite video input - BNC x 6 , 1 x S-video input - 4 pin mini-DIN , 1 x HDBaseT - RJ-45 , 1 x HD-SDI
- Included Accessories
- Remote control, HDMI cable clamp
- Security Features
- Voltage Required
- 1060 Watt
- Power Consumption Stand by
- 0.37 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 74.1 cm
- 53.4 cm
- 19.7 cm
- 26 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
- 20 - 80%
- Sound Emission
- 40 dBA
- Sound Emission (Economic Mode)
- 35 dBA
