With the control of a host PC, up to 50 terminals can be connected via the multi-PC projection from a single projector. The host PC acts as a moderator, selecting media from up to four terminals to be projected simultaneously. With the moderator function, you can maintain control and prevent tampering with what's projected on screen.
Enjoy enhanced connectivity and flexibility with Wi-Fi connectivity. Easily share and transmit images, text and files from your smart devices using the "Epson iProjection" application for smooth and smart projections. And with an additional attachment piece holding the wireless LAN adaptor in place, your transmissions will never be interrupted.
- Epson EB-X39 - 3LCD projector - portable - LAN - white grey
- 3LCD projector
- White grey
- Built-in Devices
- Speaker
- Brightness (White)
- 3500 lumens
- Brightness (Colour)
- 3500 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
- Video Input
- RGB, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 309 Watt
- 30.2 cm x 24.9 cm x 9.2 cm
- 2.7 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- White grey
Projector
- 3500 lumens
- 3500 lumens
- Brightness (Reduced)
- 2230 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.48 - 1.77:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 2 x audio line-in - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 309 Watt
- Power Consumption Stand by
- 0.2 Watt
- Software Included
- EasyMP Network Projection, EasyMP Multi PC Projection
- 30.2 cm
- 24.9 cm
- 9.2 cm
- 2.7 kg
- Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
