Epson EB-X18 XGA LCD 3000 Lumens Projector
Quicklinx: 946JWS00 Mfr#: V11H551041
High quality, bright and vibrant images
This LCD projector effortlessly displays bright images with vivid colours for a crisp, clear picture: ideal for presentations and moving images, and is aided by the 10,000:1 contrast ratio. With an HDMI input, high definition video and audio content are easily played with the same high quality you would expect from the world's number one projector manufacturer .
Colour Light Output (CLO)
CLO is an important way of measuring a projector's ability to deliver colour and, like all Epson projectors, this model has an equally high White and Colour Light Output for a bright picture with vivid colours.
User-friendly
Thanks to its manual keystone slider – unique to Epson – and automatic vertical keystone correction, this projector is quick and simple to set up. No matter the angle of the projector, you can easily align the projection to ensure a straight and correct image. The Colour Universal Design makes operating the projector easier, thanks to new LED colours and menu icons on the projector's control panel.
Wireless projector
The optional wireless connectivity4 allows you to show content easily from a range of devices without being connected to the projector via a cable.
Eco-friendly
The EB-X18 features an eco tab setting, auto lamp dimming function and an A/V mute timer.
  • High quality, bright and vibrant images
    This LCD projector effortlessly displays bright images with vivid colours for a crisp, clear picture: ideal for presentations and moving images, and is aided by the 10,000:1 contrast ratio. With an HDMI input, high definition video and audio content are easily played with the same high quality you would expect from the world's number one projector manufacturer.
  • Colour Light Output (CLO)
  • User-friendly
  • Wireless projector
    The optional wireless connectivity allows you to show content easily from a range of devices without being connected to the projector via a cable.
  • Eco-friendly
    The EB-W18 features an eco tab setting, auto lamp dimming function and an A/V mute timer.
Epson EB-X18 - 3LCD projector - portable
3LCD projector
Built-in Devices
Speaker
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
10000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video
Speakers
Speaker(s) - integrated
270 Watt
29.7 cm x 23.4 cm x 7.7 cm
2.4 kg
3LCD projector
Built-in Devices
Speaker
Projector
Brightness (White)
3000 lumens
Contrast Ratio
10000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.48 - 1.77:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, USB host function, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Direct Power On, Direct Power Off, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2
Carrying case, remote control
1 x VGA cable , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), Wireless LAN Lock
270 Watt
Power Consumption Stand by
0.28 Watt
29.7 cm
23.4 cm
7.7 cm
2.4 kg
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
29 dBA
