The EB-W29 uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-W29 comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-W29 can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
Vivid visuals
Experience image clarity with the EB-W29's WXGA resolution, offering 1280 x 800 native resolution and supporting up to 1.07 billion colors. Its 3000 lumens brightness ensures vibrant images in any lighting condition. -
Enhanced connectivity
The EB-W29 comes equipped with a wide range of interfaces including HDMI, VGA, USB 2.0, and more, making it easy to connect to various devices. Its wired LAN support allows for easy integration into networked environments. -
Flexible installation
With manual zoom, horizontal and vertical keystone correction, the EB-W29 offers versatile placement options, ensuring perfect image alignment. The projector's portability makes it ideal for presentations and multimedia use in various settings. -
Long-lasting performance
Enjoy up to 10,000 hours of lamp life in economic mode, reducing the need for frequent lamp replacements. This makes the EB-W29 a cost-effective solution for your presentation needs.
- Epson EB-W29 - 3LCD projector - portable - LAN
- 3LCD projector - 720p
- Built-in Devices
- Speaker, 0.59-inch TFT LCD
- Brightness (White)
- 3000 lumens
- Brightness (Colour)
- 3000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 270 Watt
- 29.7 cm x 24.4 cm x 8.7 cm
- 2.6 kg
- 3-year warranty
- Built-in Devices
- Networking
- Ethernet
Projector
- 3000 lumens
- 3000 lumens
- Brightness (Reduced)
- 2100 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 84 cm - 813 cm
- Throw Ratio
- 1.30 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Micro Lens Array (MLA) Technology, EPSON 3LCD technology, Whiteboard Mode, Split Screen, 16:10 aspect ratio support, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, MHL
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x VGA input , 1 x HDMI input , 1 x composite video input , 1 x component video input , 1 x S-video input - 4 pin mini-DIN , 2 x RGB input , 1 x network - RJ-45 , 2 x VGA output , 1 x serial RS-232
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Security Features
- Voltage Required
- 270 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 29.7 cm
- 24.4 cm
- 8.7 cm
- 2.6 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 29 dBA
