Epson EB-W28 WXGA 3000 Lumens Projector
Quicklinx: B25XWS00 Mfr#: V11H654041
Easy sharing
It's never been easier to take what you're seeing on a smart device and share it with a larger audience. The iProjection QR function means that any smartphone or tablet with the free iProjection app can scan the QR code projected by the EB-W28 to instantly connect and share content .
Unbeatable image quality
With WXGA resolution, 10,000:1 contrast ratio and 3,000 Lumens brightness, 3LCD technology ensures crisp images and equally high White and Colour Light Output for bright and vivid colours, and three times brighter colours than leading competitors .
Portable design
The EB-W28 can easily be carried between meeting rooms, or installed in boardrooms.
Flexible placement
A 1.2x optical zoom and horizontal and vertical keystone adjustment makes it easy to adjust your image for your environment.
Business-centric features
Easy comparisons in meetings are possible using the split-screen functionality. Multi-PC Projection software allows moderator control and up to 50 users to share content, and Epson Network Projection provides sharing of customised settings across a fleet of projectors.
Easy installation in meeting rooms
The OSD (On Screen Display) menu setting copy feature and the ability to update firmware via USB make it easy to set-up and maintain multiple projectors in a number of meeting rooms.
  • Portable business projector
    A portable business projector with innovative QR code connectivity , this 3LCD model also offers 3,000 lumens brightness.
Epson EB-W28 - 3LCD projector - portable
3LCD projector - 720p
Built-in Devices
Speaker
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
200 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video
Speakers
Speaker(s) - integrated
270 Watt
29.7 cm x 23.4 cm x 7.7 cm
2.4 kg
Built-in Devices
Speaker
Projector
Brightness (White)
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
84 cm - 813 cm
Projection Distance
1.68 m
Throw Ratio
1.30 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
200 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Micro Lens Array (MLA) Technology, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, MHL
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA input , 1 x HDMI input , 1 x composite video input , 1 x component video input , 1 x S-video input - 4 pin mini-DIN , 1 x RGB input
Carrying case, remote control
1 x VGA cable , 1 x USB cable
Security Features
270 Watt
Power Consumption Stand by
0.28 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
29.7 cm
23.4 cm
7.7 cm
2.4 kg
5 °C
35 °C
20 - 60%
Sound Emission
37 dBA
29 dBA
