Bigger is better
Whether you're watching blockbusters or delivering a presentation, this projector can achieve an impressive 320-inch display. It's great quality too, with 3LCD technology that makes the display up to three times brighter than competitor products . In addition to its bright and vivid colours, the 15,000:1 contrast ratio produces defined shadows and deep blacks. From family and friends to business colleagues and clients, it's sure to get everyone's attention.
High-quality, bright images
Even in bright rooms, this powerful yet affordable WXGA projector delivers exceptionally bright yet colourful images with clear details. It's all thanks to 3LCD technology, which produces an equally high White and Colour Light Output of 3,300 lumens.
Long-lasting solution
Looking for a long-term, hassle-free and affordable solution for your projection needs? With this model's long-lasting lamp light source, you could watch a film every day for 15 years .
Stress-free set up
Here's a projector that's designed with portability and quick set up in mind. Position the image with keystone correction and access content simply with the HDMI inputs. Thanks to the optional ELPAP10 adapter, it offers Wi-Fi connectivity allowing you to share content from a smart device using the iProjection app.
WXGA projector
For home or work, this easy-to-use, 3,300-lumen WXGA projector with optional Wi-Fi can create a 320-inch display.
- Epson EB-W05 - 3LCD projector - portable - white
- 3LCD projector - 720p
- White
- Built-in Devices
- Speaker
- Brightness (White)
- 3300 lumens
- Brightness (Colour)
- 3300 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 282 Watt
- 30.2 cm x 23.7 cm x 8.2 cm
- 2.5 kg
- 2-year warranty
- Built-in Devices
- Speaker
- Enclosure Colour
- White
Projector
- 3300 lumens
- 3300 lumens
- Brightness (Reduced)
- 2050 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 84 cm - 813 cm
- Projection Distance
- 1.68 m - 2.02 m
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.49-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2
- Included Accessories
- Wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 282 Watt
- Power Consumption Stand by
- 0.2 Watt
- 30.2 cm
- 23.7 cm
- 8.2 cm
- 2.5 kg
- Limited warranty - 2 years - carry-in ¦ Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson ELPMB23 Projector Mount | In Stock | £109.44 |
