Epson EB-W04 Versatile Projector WXGA 1280x800 HD Ready
Quicklinx: BP62WS00 Mfr#: V11H718041
15 years worth of entertainment
With a long lamp and filter life, even if using the projector to watch a movie every day, it would be up to 15 years before either would need to be changed .
High-quality, bright images
Experience exceptional-quality images that are three times brighter than competitor products thanks to 3LCD technology and equally high White and Colour Light Output. View your content like never before and pick out even the finest detail with crisp, clear blacks creating clearly defined shadows, all thanks to a 15,000:1 contrast ratio.
The big picture
Able to take content from a range of sources and display it up to a massive 300 inches, the EB-W04 uses an HDMI inputs to allow users to broadcast high-quality digital video and audio content. You can even project photos and documents straight from a smartphone or tablet with Epson's iProjection app .
Everything included for fuss-free installation
An included carry case makes for easy movement of the projector from room to room. Horizontal and vertical keystone correction mean the projector can be installed in a number of places without distorting the image.
Eco-friendly features
By varying the lamp power according to what content is being displayed, the EB-W04 can help save energy, while eco-mode helps reduce power consumption and extend lamp life.
  • 15 years worth of entertainment
    With a long lamp and filter life, even if using the projector to watch a movie every day, it would be up to 15 years before either would need to be changed.
  • High-quality, bright images
  • The big picture
    Able to take content from a range of sources and display it up to a massive 300 inches, the EB-S31 uses an HDMI inputs to allow users to broadcast high-quality digital video and audio content. You can even project photos and documents straight from a smartphone or tablet with Epson's iProjection app.
  • Everything included for fuss-free installation
  • Eco-friendly features
    By varying the lamp power according to what content is being displayed, the EB-S31 can help save energy, while eco-mode helps reduce power consumption and extend lamp life.
Epson EB-W04 - 3LCD projector - portable
3LCD projector - 720p
Built-in Devices
Speaker
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
200 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
277 Watt
29.7 cm x 23.4 cm x 7.7 cm
2.4 kg
Built-in Devices
Speaker
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
2100 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
84 cm - 813 cm
Projection Distance
1.68 m - 2.02 m
Throw Ratio
1.3 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz
Bulb type
200 Watt
Bulb life cycle
Auto Vertical Keystone, EPSON 3LCD technology, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2
Carrying case, wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
277 Watt
Power Consumption Stand by
0.26 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
29.7 cm
23.4 cm
7.7 cm
2.4 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
