Epson EB-G6350 XGA 3LCD 7000 Lumens Projector
Quicklinx: 96PQWS00 Mfr#: V11H508041
The Epson EB-G6350 boasts superior picture quality, ensuring the best possible projection for important presentations. The Colour Uniformity function compensates for unequal colour distribution by adjusting the intensity of RGB on individual areas of the screen.
New and innovative features are designed to offer the best possible presenting tools. The projector can be rotated vertically by 360 degrees so the projection image can be easily moved around the room.
The Epson EB-G6350 is easy to set up and use, thanks to a variety of user-friendly installation features. Pixel alignment, for example, enables the user to align pictures easily and effectively during set up for clear, correct images. With edge blending, a large, widescreen image can be projected from a number of projectors working together seamlessly. Its powerful zoom lens, as well as manual vertical keystone correction and centred lens, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
The HDMI input provides the flexibility to connect to high definition devices, ensuring this projector is compatible with more input sources.
For simpler integration, this model is also compatible with the Epson EB-G5 series lenses .
  • Educational projector
    Powerful 7,000-lumen EB-G6350 professional installation projector with XGA screen resolution to deliver sharper, clearer presentations.
Epson EB-G6350 - 3LCD projector - LAN
3LCD projector
Built-in Devices
Speaker
Brightness
7000 lumens
Brightness (Colour)
7000 lumens
Contrast Ratio
5000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens Shift Direction
Horizontal, vertical
Bulb type
380 Watt
Bulb life cycle
Up to 2000 hours - normal mode , Up to 4000 hours - economic mode
Video Input
RGB, S-Video, composite video, component video LAN
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
542 Watt
40.6 cm x 50.5 cm x 17.1 cm
9.7 kg
3-year warranty
3LCD projector
Built-in Devices
Speaker
Projector
Brightness
7000 lumens
Contrast Ratio
5000:1
Image Size
127 cm - 762 cm
Projection Distance
1.3 m - 14.7 m
Throw Ratio
1.29 - 2.35:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
380 Watt
Bulb life cycle
sRGB colour profile, EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), DICOM Simulation Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.65-2.55
Zoom Type
Manual
Zoom Factor
1.8x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
57% / 57%
Horizontal Lens Shift
30% / 30%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, component video, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x composite video input - RCA , 1 x component video input - BNC x 5 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 3 x audio line-in - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), security label
542 Watt
Power Consumption Stand by
0.41 Watt
Software Included
EasyMP Monitor
40.6 cm
50.5 cm
17.1 cm
9.7 kg
Limited warranty - 3 years / 15000 hours - carry-in , Limited warranty - lamp - 3 years / 3000 hours
20 - 80%
Sound Emission
37 dBA
31 dBA
