The Epson EB-G6050W boasts superior picture quality, ensuring the best possible projection for important presentations. The Colour Uniformity function compensates for unequal colour distribution by adjusting the intensity of RGB on individual areas of the screen.
New and innovative features are designed to offer the best possible presenting tools. The projector can be rotated vertically by 360 degrees so the projection image can be easily moved around the room.
The Epson EB-G6050W is easy to set up and use, thanks to a variety of user-friendly installation features. Pixel alignment, for example, enables the user to align pictures easily and effectively during set up for clear, correct images. With edge blending, a large, widescreen image can be projected from a number of projectors working together seamlessly. Its powerful zoom lens, as well as manual vertical keystone correction and centred lens, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
With the HDMI input, a variety of high definition devices can be connected to deliver HD-Ready content effortlessly.
For simpler integration, this model is also compatible with the Epson EB-G5 series lenses .
HD-Ready business projector
Powerful 5,500-lumen EB-G6050W professional installation projector with WXGA screen resolution to deliver sharper, clearer presentations.
- Epson EB-G6050W - 3LCD projector - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 5500 lumens
- Brightness (Colour)
- 5500 lumens
- Contrast Ratio
- 5000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 380 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 477 Watt
- 50.5 cm x 40.6 cm x 14.4 cm
- 9.7 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 5500 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 1.4 m - 15 m
- Throw Ratio
- 1.26 - 2.3:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- 380 Watt
- Bulb life cycle
- sRGB colour profile, instant shutdown, EPSON 3LCD technology, EPSON Cinema Filter, Crystal Clear Fine (C2 Fine), DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.65-2.55
- Zoom Factor
- 1.8x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 67% / 67%
- Horizontal Lens Shift
- 30% / 30%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, component video, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 4 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x component video input - BNC x 5 , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x audio line-in - RCA x 2
- Included Accessories
- HDMI cable clamp
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), security bar
- Voltage Required
- 477 Watt
- Power Consumption Stand by
- 0.41 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 50.5 cm
- 40.6 cm
- 14.4 cm
- 9.7 kg
- Limited warranty - 3 years / 15000 hours - carry-in , Limited warranty - lamp - 3 years / 3000 hours
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 31 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
