Excellent visibility for every student
With this Full HD projector content will be bright, vivid and clear ensuring that everyone can engage with the lesson. Providing excellent visibility, this projector is scalable up to 300 inches and is bright even in high ambient lighting conditions. It's all thanks to the high 3,800-lumen output and 15,000:1 contrast ratio.
Minimal maintenance
When resources are limited, our reliable projectors and long-lasting lamps help to eliminate downtime and unnecessary service costs. Imagine what you could achieve with minimal interruptions - our projectors help to make that a reality with up to 10 years' worth of lessons before a replacement lamp is required or the air filter needs attention .
Easy set up
Every classroom is different so you need a projector that is simple to set up and position. With our wide 1.6x optical zoom and vertical/horizontal keystone correction, it's easy to get up and running quickly.
Utilise multiple devices
Capture your students' attention and nurture a collaborative environment with hassle-free connectivity solutions. With the iProjection app, it's easy to display content from PCs and smart devices . The split-screen function can be utilised to show content from multiple devices simultaneously, while the moderator function lets you review content before it is displayed.
Bright Full HD Projector
Tick all the boxes with this bright and scalable WUXGA projector that offers multiple connectivity solutions and is simple to set up.
- Epson EB-990U - 3LCD projector - LAN - grey, white
- 3LCD projector - 1080p
- Grey, white
- Built-in Devices
- Speaker
- Brightness (White)
- 3800 lumens
- Brightness (Colour)
- 3800 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 309 Watt
- 30.9 cm x 29.3 cm x 10.5 cm
- 3.2 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- Grey, white
Projector
- 3800 lumens
- 3800 lumens
- Brightness (Reduced)
- 2440 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.39 - 2.23:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Extron Control System, AMX Control System, document camera compatible
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.5-1.9
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x microphone , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 309 Watt
- Power Consumption Stand by
- 0.2 Watt
- Software Included
- EasyMP Network Projection, EasyMP Multi PC Projection
- 30.9 cm
- 29.3 cm
- 10.5 cm
- 3.2 kg
- Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £101.71 |
