Epson EB-990U WUXGA 3LCD 3800 Lumens Projector
Quicklinx: F19QWS00 Mfr#: V11H867041
Excellent visibility for every student
With this Full HD projector content will be bright, vivid and clear ensuring that everyone can engage with the lesson. Providing excellent visibility, this projector is scalable up to 300 inches and is bright even in high ambient lighting conditions. It's all thanks to the high 3,800-lumen output and 15,000:1 contrast ratio.
Minimal maintenance
When resources are limited, our reliable projectors and long-lasting lamps help to eliminate downtime and unnecessary service costs. Imagine what you could achieve with minimal interruptions - our projectors help to make that a reality with up to 10 years' worth of lessons before a replacement lamp is required or the air filter needs attention .
Easy set up
Every classroom is different so you need a projector that is simple to set up and position. With our wide 1.6x optical zoom and vertical/horizontal keystone correction, it's easy to get up and running quickly.
Utilise multiple devices
Capture your students' attention and nurture a collaborative environment with hassle-free connectivity solutions. With the iProjection app, it's easy to display content from PCs and smart devices . The split-screen function can be utilised to show content from multiple devices simultaneously, while the moderator function lets you review content before it is displayed.
  • Bright Full HD Projector
    Tick all the boxes with this bright and scalable WUXGA projector that offers multiple connectivity solutions and is simple to set up.
Epson EB-990U - 3LCD projector - LAN - grey, white
3LCD projector - 1080p
Grey, white
Built-in Devices
Speaker
Brightness (White)
3800 lumens
Brightness (Colour)
3800 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
UHE 210 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video LAN
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
309 Watt
30.9 cm x 29.3 cm x 10.5 cm
3.2 kg
3-year warranty
Built-in Devices
Speaker
Ethernet
Enclosure Colour
Grey, white
Projector
Brightness (White)
3800 lumens
Brightness (Colour)
3800 lumens
Brightness (Reduced)
2440 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 762 cm
Throw Ratio
1.39 - 2.23:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz
Bulb type
UHE 210 Watt
Bulb life cycle
Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Extron Control System, AMX Control System, document camera compatible
Lens
Focus Type
Manual
Lens Aperture
F/1.5-1.9
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x microphone , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
Power Source
AC
309 Watt
Power Consumption Stand by
0.2 Watt
Software Included
EasyMP Network Projection, EasyMP Multi PC Projection
30.9 cm
29.3 cm
10.5 cm
3.2 kg
Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
F19Q Epson ELPMB23 Projector Mount In Stock £109.44
F19Q Epson Wireless Adaptor LAN B/G/N In Stock £98.83
