Epson EB-98H XGA 3000 Lumens Projector
Quicklinx: B9W2WS00 Mfr#: V11H687041
The EB-98H uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-98H comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-98H can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
  • Enhanced connectivity
    With a wide range of interface options including HDMI, VGA, and composite video inputs, the Epson EB-98H ensures seamless connection to a variety of devices. This versatility enhances user experience by facilitating easy setup and integration into any presentation environment.
  • High image quality
    Boasting 3000 lumens of brightness and a dynamic contrast ratio of 10000:1, the Epson EB-98H delivers vivid, sharp images in full color. The projector supports 1.07 billion colors, ensuring that presentations are vibrant and engaging, with XGA resolution providing clear, detailed visuals for an immersive viewing experience.
  • Flexible installation
    The manual zoom, horizontal and vertical keystone correction allow for flexible placement in any room, making it easy to achieve a perfectly aligned image. The projector's portability and the range of image size from 76 cm to 762 cm offer versatility for various spaces and audience sizes.
  • Advanced audiovisual features
    Incorporating EPSON 3LCD technology and multiple projector features such as Blackboard Mode, Whiteboard Mode, and Split Screen, the EB-98H is designed to enhance any presentation. Whether it's a classroom setting or a corporate boardroom, these features ensure optimal viewing experiences in diverse lighting conditions and presentation contexts.
  • Eco-friendly and economical
    The Epson EB-98H is designed with efficiency in mind, featuring a lamp life cycle of up to 10000 hours in economic mode. This not only reduces the need for frequent lamp replacements but also contributes to lower total cost of ownership and environmental impact.
Epson EB-98H - 3LCD projector - portable - LAN
3LCD projector
Built-in Devices
Speaker, 0.55-inch TFT LCD
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
287 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video LAN
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
287 Watt
29.7 cm x 24.4 cm x 8.7 cm
2.7 kg
3-year warranty
3LCD projector
Built-in Devices
Ethernet
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
2100 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.8 m - 2.17 m
Throw Ratio
1.48 - 1.77:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
287 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x microphone input - mini-phone stereo 3.5 mm
Carrying case, remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
287 Watt
Power Consumption Stand by
0.26 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
29.7 cm
24.4 cm
8.7 cm
2.7 kg
Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
29 dBA
