The EB-945H uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-945H comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-945H can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
3LCD technology
All Epson projectors are based on 3-chip LCD technology for amazing color, incredible detail and solid reliability. 3LCD's 3-chip architecture dedicates an entire chip to process each primary color - red, green and blue, continuously. Unlike single-chip technology that delivers color sequentially, you get full-time color. The result is vibrant, realistic images and video all delivered with 3LCD's true-to-life color. -
Maximize the display with split screen
Split Screen allows inputs from two separate sources to be displayed side by side on the same screen. For example, images from a document camera and PC could be projected at the same time. -
Versatile connectivity
Not only does the wide-ranging interface correspond with conventional analog sources, it boasts two HDMI inputs. One of which also acts as a MHL terminal (HDMI 2 port). MHL is an innovative technology allowing you to mirror high definition content and charge an Android device via a single MHL cable. -
Horizontal Keystone slider
The Horizontal Keystone slider allows for quick and easy adjustments to correct image distortion. With a single touch a broad range of placement options become available. -
Conveniently collaborate with Multi PC Projection
The Multi-PC Projection feature allows a network of up to 50 PCs to be connected to a single projector. The feature allows a host PC to act as a Moderator who can then select up to 4 of the connected devices to be projected on the screen. The Moderator function allows the user to control what image is projected on the screen and prevent tampering. -
Advanced networking
With the EB-945H, it's possible to monitor and control networked Epson projectors from a remote location. Schedule power on or off timings, check projector status and receive maintenance alerts. Users can even project presentations in up to four rooms from one networked location. -
Auto Power on
The EB-945H comes with an Auto Power feature, providing a quick start to any meeting or class. To start automatically, simply connect to a source device via VGA while the projector is in standby. There is no need to reach for the power button or go looking for the remote control.
- Epson EB-945H - 3LCD projector - portable - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness (White)
- 3000 lumens
- Brightness (Colour)
- 3000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 287 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 287 Watt
- 29.7 cm x 26.9 cm x 8.7 cm
- 2.9 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- 3000 lumens
- 3000 lumens
- Brightness (Reduced)
- 2100 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 1.69 m - 2.75 m
- Throw Ratio
- 1.38 - 2.24:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 287 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Voltage Required
- 287 Watt
- Power Consumption Stand by
- 0.26 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 29.7 cm
- 26.9 cm
- 8.7 cm
- 2.9 kg
- Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 29 dBA
