This new projector offers ultimate interactivity by combining finger-touch with dual pen capability. With a brightness level of 3,800 lumens and FullHD WUXGA resolution, the EB-696Ui's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 16,000:1 contrast ratio and HDMI input means that students benefit from sharp, clear images.
Quality image
Epson’s 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors1. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality.
Finger-touch and dual pen
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, teacher and student or two students can work simultaneously using different attributes.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
Save time
Simply plug in and turn on – there's no warm-up time and the PC-free annotation mode means that teachers don't even need to power up their computers. The interactive function does not require drivers to be installed and it auto-calibrates.
Interact and enhance learning
Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what content to display. Combine two projectors to create one large interactive display.
Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality. -
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, teacher and student or two students can work simultaneously using different attributes. -
Reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode. -
Save time
Simply plug in and turn on – there's no warm-up time and the PC-free annotation mode means that teachers don't even need to power up their computers. The interactive function does not require drivers to be installed and it auto-calibrates. -
Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what content to display. Combine two projectors to create one large interactive display. -
Wireless capability (Optional)
Show content easily from a range of smart devices using the iProjection App.
- Epson EB-696Ui - 3LCD projector - LAN - grey, white
- 3LCD projector - 1080p
- Grey, white
- Built-in Devices
- Speaker
- Brightness (White)
- 3800 lumens
- Brightness (Colour)
- 3800 lumens
- Contrast Ratio
- 300:1 / 16000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 267 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode ¦ Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 401 Watt
- 47.4 cm x 44.7 cm x 13 cm
- 8.3 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- Grey, white
Projector
- 3800 lumens
- 3800 lumens
- Brightness (Reduced)
- 2700 lumens
- Contrast Ratio
- Image Size
- 178 cm - 254 cm
- Projection Distance
- 0.4 m - 0.6 m
- Throw Ratio
- 0.27 - 0.37:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Bulb type
- 267 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- RGB, S-Video
- Video Interfaces
- VGA, HDMI, S-Video, MHL
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out
- Included Accessories
- Pen tray, wireless remote control, pen case, finger touch unit, interactive pens
- Cables Included
- 1 x USB cable
- Mounting Kit
- Included
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 401 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 47.4 cm
- 44.7 cm
- 13 cm
- 8.3 kg
- Limited warranty - 3 years / 8000 hours - on-site ¦ Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 30 dBA
Epson ELPMB23 Projector Mount | In Stock | £109.44 |
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £101.71 |
