Epson EB-535w Short Throw WXGA 3400 Lumens Projector
Quicklinx: B225WS00 Mfr#: V11H671041
High-quality image
Complete with our 3LCD technology, the EB-535W displays superior-quality, bright images with more accurate colours. The image can be seen even in brightly-lit rooms thanks to an equally high white and colour light output. Image detail is clear thanks to a high contrast ratio and our new short throw lens means sharper images and improved focus.
More value for your money
The lamp in the EB-535W now lasts up to 10,000 hours in eco mode. The projector even conserves power during presentations by automatically adjusting the light output depending on the content. The A/V mute function pauses the presentation and dims the lamp by 70% to conserve energy while the projector is not in use. The projectors' built-in 16w speaker means audio content can be played directly through the projector, without the need for additional external speakers. The microphone input transforms the projector into a PA system, meaning presenters can be easily heard in a classroom environment.
Easy to set up and use
The EB-535W has both horizontal and vertical keystone correction to achieve a perfectly shaped image and help avoid distortion. When setting up several projectors, the OSD settings can be copied from one projector to many others meaning you don't need to set up projectors individually. Multi-PC projection software allows content from four devices, including PC's, tablets, smart phones, to be displayed simulatenously.
  • High-quality image
  • More value for your money
  • Easy to set up and use
Epson EB-535W - 3LCD projector - LAN
3LCD projector - 720p
Built-in Devices
Speaker, 0.59-inch TFT LCD
Brightness (White)
3400 lumens
Brightness (Colour)
3400 lumens
Contrast Ratio
16000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
215 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video LAN
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
298 Watt
34.4 cm x 31.5 cm x 9.4 cm
3.7 kg
Built-in Devices
Ethernet
Projector
Brightness (White)
3400 lumens
Contrast Ratio
16000:1 (dynamic)
Image Size
134 cm - 294 cm
Projection Distance
0.5 m - 1.2 m
Throw Ratio
0.48:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
215 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-15 / +15
Horizontal Keystone Correction
-15 / +15
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
1 x HDMI input - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm , 2 x component video input , 1 x serial RS-232
Remote control
Security Features
298 Watt
Power Consumption Stand by
0.28 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
34.4 cm
31.5 cm
9.4 cm
3.7 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
B225 Epson ELPMB23 Projector Mount In Stock £109.44
B225 Epson Wireless Adaptor LAN B/G/N In Stock £98.83
B225 Epson Epson Short Throw Projector Wall Mount - ELPMB45 - ST EB52 In Stock £133.36
B225 Epson ELPLP87 Projector lamp UHE In Stock £61.86
B225 Epson ELPDC07 Digital Document Camera In Stock £180.47
